What is remarkable to me that while having explain this to so
many, I am wondering, "Am I the only guy who ever did models in
silver, who is still alive, and all the rest of modelmakers are
dead" ?
You see, this is not a great mystery and should not be such a
revelation. The fact that holes after casting are large, is very
basic and mandatory adjustment that any modelmaker makes.
Very strange observations indeed, Leonid. You see, I also have made
models in silver for many years, both as hand made models, and more
recently, as CAD/CAM models made from cast CAD/CAM waxes, and molds
then made from the silver casting, or the silver hand made model.
Everything I’ve ever noted is that holes, and spacing between them,
and other measurements, are all smaller. Casting shrink. Exceptions
are occasionally in platinum, or with certain high expansion
investments, where the thermal expansion of the mold from burn out,
exceeds the shrinkage of the metal upon cooling. But that isn’t metal
expanding, or holes becoming larger. That, in essence, is casting
into an enlarged (holes included) mold.
In another post, talking about ring sizes being smaller after
casting, you quite clearly explained exactly what happens, that the
metal shrinks upon cooling, and that the overall shrinkage of the
whole piece overcomes the slight enlarging of the hole from metal
shrinking away from the hole. You are correct that metal next to the
hole shrinks, pulling away from that edge of the hole. But as with
rings, the overall shrinkage of the whole piece is greater, and the
hole still does become smaller.
Effects that can mask this effect:
Oxidation of the casting which gets pickled off and results in
slightly less metal at the surface. That can slightly increase a hole
size. Doubtful that it would still be enough to make it larger than
the hole in the wax or model, but not impossible, depending on the
metal. The same with rough cast surfaces, from burnout problems, or
metal/mold reactions.
And then there is what happens in the other example you gave, that
of hollow cored lost wax castings. That’s actually an interesting
case, with a more complex explanation. You are correct that in such
work, the core pins often are loose in the cooled casting. But the
reason is not simply enlarged holes from metal shrinkage. Rather,
it’s a combination of factors. The main one is that the rate of
thermal expansion of most casting investments, including sculptural
investments or sand mold products, is less than the thermal
expansion rate of the metals. Even if the mold is hot, the core
shrinks less than the metal upon cooling, and the trapped core exerts
some pressure on the solidifying and cooling metal, literally
stretching it at the same time as it’s trying to shrink from cooling.
This happens even more with larger molds which often are cast at
relatively cooler mold temperatures. However, at the same time, the
metal core pins, being fairly small in bulk, are easily heated up by
the entering molten metal, and they have enough chance to expand from
heating before the cast metal solidifies, that they are then cooling
the same as the cast metal. However, they are not constrained by the
core in their rate of shrinkage, so can fully shrink. The casting
itself, however, is stretched slightly by the core inside, which has
nowhere else to go, and in that stretching, it also takes the hole
size with it, just as a dot or circle drawn on a balloon expands as
you blow up the balloon. Add in a little oxidation on the pins so the
pins and the cast metal don’t fuse, and you’re easily left with loose
core pins. The holes around the core pins simply weren’t allowed to
shrink quite as much as they might have “wanted” to.
The bottom line, Leonid, is that while you are indeed correct that
metal shrinks away from a hole on cooling, It is also shrinking by
the same percentage in every other direction at the same time,
including the much larger dimensions of the overall piece, which
overwhelms any slight expansion of the holes. That overall shrinkage,
however, since it’s always of a larger dimensioned article, will
overcome the shrinkage of a small detail like the metal next to a
hole. This is true even if the hole is almost as large as the overall
casting, such as casting a simple jump ring. The hole in that cast
jump ring will be slightly smaller than the hole in the wax model it
was cast from. Thermal shrinkage is a simple percentage of the linear
dimensions in all directions, unless the metal is physically
constrained by something else, such as pressure from the mold, or
stresses from uneven cooling, or the like.
And while there may indeed be situations where some other factor
related to the casting process that might degrade surface integrity
or dimensions (for example, an incomplete filling of the mold can
result in metal not quite reaching the sharp edges of a hole or the
end of a prong, or the like) might affect the hole size, most of us
have not found those effects to be such as to give us larger holes
upon casting. That’s true for ring sizes, and it’s true for the
holes into which stones will be set.
Leonid, I don’t question the fact that you have many years of
observation of the metal behind you in your career. But please also
understand that this is also true of many of the readers here on
Orchid, every one of which, at least from those many of us who’ve
responded to your thought here, have not found their/our observations
to be the same as yours. While I don’t suggest you’re stupid or
anything like that, I’d like you to also concede that we aren’t
either. More than a few of us have, in addition to extensive jewelry
experience and training, more than a little training in metallurgy as
well. You’re the only one who’s alleging that holes get larger
routinely as a result of thermal shrinkage. Might you consider that
if so many of us have directly observed the opposite, and that the
opposite also nicely fits any reasonable explanation of the way
metal shrinks upon cooling, that you just might have been explaining
your observations with the wrong conclusions? Could there be some
other factor in your processes over the years that could explain how
you’ve arrived at this belief? Might you perhaps have come to this
belief based on a few observations and have since simply assumed it
was happening even if it wasn’t actually doing so?
Just as you wonder how you seem to be the only one who’s experienced
this effect, many of us are wondering the same thing, only we’re not
assuming that our lack of observing this effect is due to our
inexperience, as you seem to be doing. We’re instead wondering how
you seem to have come to this conclusion that to us, contradicts
everything we’ve been taught, and have learned by experience, about
the way metal behaves. And I remind you that while some on Orchid
are newcomers and beginners, more than a few of the people who’ve
replied to this thread are quite assuredly not in that category, just
as you are not. While it’s always possible that you are the only one
in the group to know the truth, and the rest of us are wrong, that is
statistically rather unlikely.
Peter Rowe
