In real world, it is not achievable.
In my opinion, the greatest compliment I can get from a fellow
goldsmith is “Wow! How’d you do that?” I love to try the impossible,
and encourage everyone to try to achieve the unachievable at least
once. You just might surprise yourself.
I don’t have a lot of experience with invisible setting, but I have
been talked into doing a bit of it and associated repair work. Here’s
how I do it, and from my limited experience how most people do it.
For a two row setting, the girdles of princess cut stones are grooved
along one side (for rails) or three sides for (square holes). The
settings usually are square holes that are azured on both top and
bottom forming a sharp edge that fits into the groove, with the
outside channel prepared much the same as a baguette channel. The
seat is carefully cut for the stone, one at a time, the stone is
fitted into the hole with the grooves fitted onto the azured edges.
The outside girdle is then lowered into the seat on the outside
channel, and the outside channel is then hammered down, just like
setting a baguette into a one-sided channel. A flat graver is then
used to press the azures into the grooved girdle and the next seat is
prepared and the stone is set, permanently holding the azure pressed
into the first stone by the graver. The process is repeated until the
final stone is set, usually hammered down on two adjacent sides, the
outside channel and the end of the row, just like a baguette or
princess, tightening up the entire row.
For three or more rows, it’s done the same way, except the stones in
the center row are grooved on four sides, and the stones are set from
the center out. The pressure from each stone holds the azure on it’s
adjacent stones in place. Don’t know about cast-in-place, but I would
expect a bunch of chipped corners and loose or missing stones.
The reason it gives people such fits is that the seats are
absolutely unforgiving of even the slightest errors in layout or fit
before or after setting. Any single error or poor fitting seat is
multiplied, and affects all the adjacent stones, which in turn
affects all of the stones. It is also quite a pain to have to reset
stones that fall out and nigh on impossible to tighten stones that
get loose without unsetting adjacent stones to allow access to the
loose stone’s seat, which will more than likely require rebuilding.
It is not unusual to find that invisible set stones are glued to stop
them from rattling (gee, I haven’t seen that since this morning). The
best way to avoid trouble with invisible settings is to assume they
are poorly set and glued, clean them very gently and quickly (don’t
use the ultrasonic if possible), never steam them from the back,
never heat them any more than absolutely necessary (or more than you
can hang on to with unprotected fingers - the heat can burn glue or
distort the seats during expansion and contraction which can cause
loosening), and be very cognizant of the reshaping of the piece that
will be caused by whatever you are being asked to do, like sizing.
Then tell the customer there is no guarantee whatsoever. Then tell
them again, and maybe one more time just to make sure they
understand. It is also helpful to charge exorbitantly so that if they
do say OK, you will have the time to fix it if things don’t go well,
or enough money to send it to someone that can fix it for you.
Invisible setting isn’t impossible or even all that difficult if you
can successfully channel set baguettes. It just requires extreme
precision and attention to detail at every step to be done well.
Dave
