why does hand made have to be better than cast ?
Is a casted piece inferior to something else? I have seen a lot of
jewelers manufactures in my life - good and bad things. Perhaps i
should introduce my self at this point, well knowing that words on
papers doesn’t count. My name is Mario Sarto. I am a goldsmith with
master craftsmans diploma, i am an instructor and a trained designer.
Our family do this craft since 1767. Our son, i hope, will be the
eighth generation. In this long time we have used every technology
that was available on the market to date inclusive the latest casting
machines with over- and low pressure and vibration.
Some are upset about the terms handmade or casted. But why? A simple
pencil is a tool, a hammer is a tool. A computer, a milling-machine,
a casting-machine - they are only tools in my hand! They can only
do what i want them to do. Every piece of this tools has its pros and
cons. Humans are limited by them self. We are not able to drill a
hole by hand like a milling-machine can do. But remember, the machine
only does, what i want it to do. So at the end, nearly everything is
done by hand. Do i hear someone saying carving a wax clump by hand is
more quality or/and more worth? I say no! It could be done by a
machine much more accurate and much faster every time you want. This
is not the point about we should altercate.
The question was, if handmade is better than casting. I repeat,
related to design, no, related to quality, yes. Define handmade:
fabricate a piece using the techniques casting, milling, annealing,
forging, sawing, bending, welding, soldering and polishing. Define
casting: fabricate the same piece using the techniques casting and/or
CAD/CAM (wax-casting) without milling and forging!
I have posted a picture someone called a “nice line art”.
It's already been mentioned that the difference would only be seen
using a microscope.
Please believe me, i don’t want to affront anyone, but my answer to
that is, learn the metallurgical basics first. I can see the
difference with the naked eye, i can feel the difference when
polishing and engraving such pieces and i have worn casted pieces on
my bench every day. Yes, casted pieces nagged much earlier than
forged ones, they don’t have the durability. And there is another
thing i often see on casted pieces, it is the bad finish. Wire,
prongs and openings are bad polished or they are not at all polished.
The rough casted-surface is viewable often. I don’t say all, i say a
lot of them. The question is why? There are only two possible
answers. The first is, the piece has to be cheap and a lot of
reworking will not be paid. The second answer is, the jeweler is not
able to do a high quality refinishing job.
Another often seen thing are the alloys used when casting,
especially when casting Platinum. A lot of jewelers use the poor
Platinum-Cobalt alloy. Yes, it is great for casting, but it has the
appalling physical quality of them all. Much to soft when used as a
ring shank…
What are the pros for casting? It is cheaper because it could be
done in a short time. A intricate piece could be done in less than
three hours. It is cheaper because it could be done by a semi-skilled
worker. And the biggest pro is you can produce a lot of equal (or
different) looking pieces any time you want in one go.
But when it comes to real high quality, no casted piece can beat a
piece made entirely by hand from a long lasting skilled
bench-jeweler/goldsmith.
Mario Sarto
