In order for "black color to bleed into diamond" a ray of black color must enter a diamond. Since ray of black color cannot exist, therefore no "bleeding" can take place.
What you say is only partially true. Yes, you’re right that no black
rays of light exist. However, take a diamond in a new, tarnish free
setting, with mirror bright surfaces. Many diamonds are not ideal
cut and so may leak some light out of the pavilion facets. These rays
will be reflected back by the mirrored surfaces of the setting.
Alternatively, take a tarnished setting where the metal in contact
with the pavilion has turned black. Any light rays leaking from the
pavilion will be absorbed by the black colour. Black absorbs light
rays rather than reflecting them. Therefore light is lost and the
diamond WILL look darker just as Daniel and others have said.
therefore setting cannot have any influence on well cut diamond.
The majority of diamonds are not well cut and as Daniel has pointed
out, this particular part of this thread came about by someone
mentioning old mine cut or rose cut diamonds which are far from ideal
or well cut diamonds. In theory, in a perfectly cut round brilliant
diamond, all light entering through the table of the diamond will be
reflected/refracted around inside the stone and will emerge back out
of the table to the viewer’s eye and in such a case the setting
shouldn’t make any difference, but those diamonds are very few and
far between. Even then, there are diamond “experts” who say that
yellow gold settings will give a colourless diamond a yellow cast,
while others say it shouldn’t affect it. There’s probably been lots
of research done on such things.
Helen
UK
