Several months ago we had a discussion of using titanium for
supports when soldering.
For the last 3 years, I have used L shaped pieces of titanium sheet
to elevate sterling above the soldering board. It doesn’t solder to
the work and doesn’t act as a heat sink. The sheet I cut up was about
24 gauge, cut to 60mm x 8 mm, bent into an L.
When I started using argentium, the sag problem which occurs when
applying bezels is a real nuisance. So I explored using titanium mesh
of some kind. James Binnion kindly pointed out that titanium has a
relatively low flash point in mesh with very fine wires. So I went
looking for expanded metal in titanium. Alan Mason found it first and
shared half with me. The expanded metal has a cross section of about
2mm at its thinnest point. I sliced my half into 2 x 3 inch pieces
and find it superb as a support when working silver and gold.
Has anybody else tried it?
Judy Hoch - in Colorado with still over a foot of snow in my yard and
piles five feet high on the street, and more coming tomorrow. How
about you folks back east with cherry blossoms - want some white
stuff?
