I love my foredom micro motor. I have a 1090 kit. it comes with the
new hammer hand piece that sences resistance befor it begins to
‘kick’. this gives me a great deal of control over the hammer piece.
there is also an assortment of new anvil points that are avaliable,
ball, square, cylinder, rectangle and even a bezel rocker shaped
point!!! the combinations of the new anvil poins and the new hammer
hand piece is a wonderful advancement for the tool. There are also
graver attachments for the hammer hand piece.
The foredom k1070 is the control box with the micro motor, the k
1090 is the control box with the micro motor hand piece and the new
hammer hand piece. You can use either one. keep an eye out for the
new micro grinder that was just developed for this unit.
I demonstrate these products at some of the larger trade shows and
test them out all the time. I do find them to give me much more
freedom of movement. They do seem to have less torque than a flex
shaft so if i am running at a low speed I tend to pulsate the
pressue on the bit when drilling through metal. if you are at a
higher speed there is no need for this at all. My issue with running
at the high speeds is that I risk the chance of burning up my bur.
my friend was purchasing one of these from me and asked me to
perform a test for him. I put a 2mm round bur in the micro motor,
turned the speed control to half way and drilled through a 2mm piece
of half hard copper, it went through it like butter. keep in mind
the foredom goes 38000 rpms so me setting it at half speed on the
control unit was to save my bur. I have looked at some other units
and noticed that the speed control on the control box does not
always over ride the foot pedal. the foredom does over ride the foot
control, so if you set it on 25% speed and floor the foot control
you will only 25% of its maximum speed. That is worth its weight in
gold for me. I would like to know if any other micro motor unit does
this.
Again, the k1090 is the control box, the micro motor hand piece and
the hammer hand piece. to really take this thing over the top check
out the fact that it is designed to go anywhere, it travels very
easily around the shop, from store to store, to a trade show or even
around the world… it has a voltage selector switch on the
back that goes from 110/120 or 220/240 once you have one you will
fall in love with it, it will not take the place of your flex shaft
but it could. It feels like a feather in your hand.
also keep in mind that the micro motor handpieces are set up as
quick release 3/32 collets. You can change these to 1/8 or 3mm if
you wish.
If 38000 rpms is not fast enough, check out the k1050 unit from
foredom. It goes up to 50000 rpms, it is brushless and has more
torque… however as of now no hammer handpiece attachment and no
voltage selector.
“why get a foredom micro motor and not the cheap charlie version,
they look the same” asked my friend. well foredom test every product
that goes through the factory befor shipping it to you the user. if
you go with a cheaper version chances are the collet, the circuit
board or something else may not be up to par with the intended
design, but hey, you will never know because you may not have
another to compare it to. Also foredom stands by there warrantee and
works on everything at there Bethel, Conn. headquarters.
too much …hardly. if you need more contact me. I have
sold hundereds of these because I believe in them 100%. I will give
you a fair price on one if you would like to try one. I will even
give you 30 days to return it with no questions asked. OR go to your
local tool supplier that you know and love and give them your
business tell them “BUZZ” Werner sent you… I am an independent
jeweler and foredom disributor/demonstator 410-942-0027 or go to
www.foredom.com and check it out… then talk to me… i am
much more fun than Mike Zagielski the national rep for
foredom… he is still listening to the moody blues diving around
in his dodge dart.
Wayne Louis Werner
