I really don’t get the whole bezel roller thing. I bought one at the
start of making jewellery, because that’s what everyone else seems
to use for turning bezels, but I found them extremely difficult to
use, causing me a great deal of pain to my hands and wrists.
The only way I can see bezel rollers working, is if people are using
extremely thin gauge sterling silver for their bezels, or fine
silver. In the case of sterling, if it’s that thin, it just looks
cheap and nasty, and you often see gaps next to the stones, because
it doesn’t have the “squish” factor of thicker metal, which you can
compress far more. You can end up with puckering at corners too. With
fine silver, the metal is SO soft, that the bezel can get damaged
extremely easily, or simply scratched too quickly.
So I go for sterling silver, of at least 0.5mm thickness (not sure
what gauge that is). I sometimes make my bezels out of 1.0mm thick
sterling, for larger stones. I always make my own bezels. The
commercially available bezel stock seems to only be available in
0.3mm thickness or thinner, which is far too thin for my liking. Both
the thicknesses I use are impossible to turn with a bezel roller - at
least for me. So I use a bezel pusher, which in my case, is a wooden
handle with a square section steel rod sticking out of it. I have
filed a very slight dome on the end face of it, so that it doesn’t
dig in and cause dents, when I’m turning a bezel. I use it with a
chasing hammer.
Obviously, for this method, you need both hands free, so you need to
mount the piece of jewellery in something sturdy. In my case, I use
an ordinary bench vice and I set the jewellery into GRS’s
Thermo-loc. Any other thermoplastic will do the same job. Heat it up
in a jug of water in the microwave (that way the plastic doesn’t
burn), and allow to cool when the piece is set into it. I make a sort
of “T” shape with the plastic, so that the jewellery sits in the
horizontal piece of the “T”, and the vertical part goes in the vice
jaws. Push the piece of jewellery into the top of the plastic,
bringing it up the sides enough to secure it. Make sure if setting
open backed settings, that you push any thermoplastic down out of the
settings, so that it’s not in the way of the stones’ pavilions. Set
your stones, then put back in the jug of water in the microwave, to
soften the plastic so you can remove the piece. Being under water
means that your piece of metal jewellery will NOT cause a problem
with the microwave. Take care when handling the hot thermoplastic -
and with the hot water!
I always make sure my bezels fit the stones snugly, and that they
are only just tall enough to secure the stone when set, so that there
will be no gaps after stone setting. The thickness of the metal I
use, means that even when setting stones with sharp corners, there is
enough thickness so that the compression takes up the slack, and
there is no puckering of corners. I make sure the forces I’m
applying, go away from the corners, towards the centres of the sides,
and as such, no ugly slits or wedges need ever be cut at the bezel
corners. Occasionally, there will be a little extra bulk at the
corners, which just needs to be filed and sanded flush with the rest
of the bezel profile afterwards. This is quickly and easily done,
prior to its final polish.
Obviously I’m not saying that my way is the only way stone setting
should be done - there are other ways. But it is the only way that
I’ve found to make sturdy, neat bezels using sterling silver, of
adequate thickness, that will stand up to daily wear for many years.
It is my opinion, based on the “butter” softness of sterling silver,
and its propensity to scratch, dent and go out of shape easily. I’ve
also tried fine silver once, and will never use it again because it
is far, far too soft. It went out of shape with me just shaking some
water off it - and I’m not talking about a huge piece, just a
hemisphere of about three quarters of an inch in diameter, and about
0.5mm thickness!!! I like to make rings, set with stones - rings
that will last for many years, and so I use sterling silver
(sometimes Argentium) of a thickness that will make a decent piece of
jewellery. It’s also not a quick fix. It’s probably taken me the best
part of three years to be completely happy with my bezel setting (I
set mostly faceted stones in bezels. Cabochons are easier to set, but
still have some basic rules to ensure a really neat fit).
If any new folks are having difficulties getting neatly set stones,
using either sterling which is too thin, or fine silver, and want
more details about the above method, I’ll happily provide
comprehensive for them to try - just email me offline, or
I could possibly do a blog. My methods are a combination of lots of
advice which I received from other Orchid members, when I was new to
making jewellery, so I’d just be returning the favour.
Helen
UK
