With great interest I have been following the posts on this subject.
I am not surprised to see that there are various view-points on the
subject, but there is also a lot of misLet me try to
clear up some of it.
Hardness. How hard is platinum? well it ranges from 40 HV to 380 HV
depending on the alloy combination and treatment. For instance a
Kretchmer tension ring is so hard that the common jewelers saw wont
cut it and attempting to do so will only dull the blade. The main
reason why people have issues with denting and bending and
scratching is the fact that they use the wrong alloy for the job.
Pt950/Ir is NOT a casting alloy. With the hardness of 80HV is is way
too soft for casting, BUT, many jewelers use it because the “setters
like it” and it “engraves like butter”. Of course the customer will
then have to deal with denting, bending and such, but the setters are
happy. As a fabrication alloy, however, Pt950/Ir is wonderful and
work hardens rapidly to over 180 HV.
Casting alloys are Pt950/Ru and Pt950/Co ( hardness 130/135 HV)
Universal alloys are Pt900/Ir and also Pt950/Ru. Both are good to
cast, excellent for hand fabrication and great for tubing to make
machined wedding bands.
Platinum is the most precious precious metal. It is far more
resistant to destruction by nature than any other precious metal.
Case and point: to dissolve it, Aqua Regia has to be boiling, for
other metals it can be room temperature.
Platinum is far more rare that gold (30X) and should not be compared
to gold as the two are not related. There is absolutely no
comparison to white gold. Yes they may look similar, but Pt has no
stress corrosion, is hypo-allergenic and does not wear away over
time. It is naturally white and should never be rhodium plated.
The high gloss polished look that some jewelers put on platinum is
really not the proper finish. Platinum is not meant to be polished.
That is the white gold look…add rh plating and your platinum piece
looks like a white gold ring.
Not my choice. I like the traditional satin or engraved finishes and
allow for it to develop the natural patina that platinum is known
for all over the world.
As far as soldering is concerned, the traditional Pt solders in this
country have been mixtures of Pd and Ag and only the very high
temperature solders contained any platinum at all. To overcome this
challenge the metal providers make Pt952 when they sell you a Pt950
alloy. That 2 ppt makes up for any metal used for solder that does
not contain platinum. This has been overcome with the recent
development of high purity (plumb) solders which may contain as much
as 95% platinum.
When platinum jewelry is designed and made for platinum and is not
ring #xyz that one can have in gold/silver or whatever and also in
Pt, is made from the proper alloy, burnished and polished or
decorated as platinum should, the piece will outlast anything!
Period. So yes it costs more, yes it may be a challenge to work with
to some, but with the proper education and understanding it is far
less complicated to work with than many other metals out there.
Platinum is not difficult, it is just different.
Feel free to send your questions to me or ask for or
help with technical issues.
Jurgen J. Maerz
Director of Technical Education
Platinum Guild International
