Hello,
(Sorry for the delayed reply)
Thank you, NeilTheJeweler, for your response. I shall try the blue
platinum rouge right away.
I am glad you mention that because the compounds seem to be another
one of my problems.
I am polishing a flat sterling silver disc.
I use a yellow treated buff with graystar first. I polish the back
and it gets nice and shiney. Then I polish the front and it gets nice
and shiney.
But, now the back has smudges from my fingersâŚwhich doesnât all
seem to be coming off when I âswooshâ in the ultrasonic (just heated
solution for now, as I was afraid of the sonic until I heard back
from the orchid group).
There is often a slight shadowy remainder.it wonât rub off, or scrub
off with a toothbrushâŚso then, I head back to the polisherâŚit is a
vicious circle
I am really trying to think everything through, but I am
strugglingâŚit seems like it should not be this difficultâŚmy friend
said âyou are making it too hardââŚbut all I am trying to do is
polish the discâŚ
So then I started to follow the yellow treated/ graystar with a
tight weave muslin buff, to take off excess compound real quick on
the front and back. This seemed to be helping, but I just feel like
as the ultrasonic used normally works for many other people, so I
must be doing something wrongâŚthe same thing happens with the red
rouge, but not as muchâŚ
I have tried loading the buff with more compound, loading it less,
using my buff rakes, working on my hand motions, etc.trying to find
the right feel/ balance/resultsâŚ
May I ask why you suggest to nix the steamer?
(I just got a good deal on a used Reimerâs from a friendâŚI do like
the way it leaves the piece all nice and spotlessâŚ(not including the
white spots of course!) and I know what you mean, because if the
graystar smudges or rouge do not come off all the way in the
ultrasonic solution, the steamer isnât going to remove/clean it
either. It seems like I just like the steamer to dry the piece
nicelyâŚ(kind of expensive just for thatâŚbut I got it, so.)
And, when there is the faint shadowy smudge left on the piece, then
I get a different kind of white hazeâŚa cloudy, uneven ring around
the perimeter of the back of the disc. (which is slightly concave as
it is a die struck discâŚ) But by then, I am not sure where that
white cloudy haze is coming fromâŚthe ultrasonic? Or the steamer? I
know for sure the splotchy white haze ones came from the ultrasonic
pulse and extended submersion in the heated solutionâŚwhich seems to
have stopped since I stopped using the pulse.
I am strugglingâŚ
Best Regards,
Julie
