Hi guys. i am hoping someone can help me with this. i am trying to
ball up 26 gauge sterling wires which is in the form of headpins. on
one side of the pins ae pink tourmalines, the pin is then threaded
through a 20 g sheet with holes in it and i am trying to ball up the
wire on the side opposite the gems. I have a acetylene B torch, not
an oxy/acetylene. i am using vigor heat shield to protect the stones
from the heat. The problem is, i cannot get the wires to ball up! i
have actually melted the 20 g sheet below before the wires started
to ball up. Obviously they are not getting hot enough but why? I have
seen people do this so I know it is possible. What am I doing wrong
and how can I make this work? Is the heat shield goop just too big
of a heat sink and if so, why does the sheet still over-heat? I’m
confused. thanks for your help.
Sue Szabo
www.lsueszabo.com
lsueszabo on etsy
