Taylor Manufacturing Cuti-pi scroll saw
I just procured a used Cuti-pi scroll saw. It did not come with any instructions at all and I cant seem to find any on-line. Does anyone here. have a copy of the user manual? I think I have it assembled correctly as I was able to make a couple of cuts, but I have questions about blade insertion points, what is the proper blade tension, best speeds for particular thickness or materials, maintenance of machine, maximum thickness, etc. Any info or tips would help would help! Thanks in advance. --Dan
Do a search using Duckduckgo.com as your search engine and you will get all sorts of links………………….
JD
Thanks John, I found several links that mentioned Cuti-pi, but none of them addressed my questions. Would really appreciate a copy of the manual!
