What a day! There I was, minding my own business, enjoying plodding
through the fabrication of my youngest daughter’s prom jewellery when
in walks my son’s girlfriend bearing a brown envelope and wearing a
sheepish grin on her face. She then revealed a colleague’s engagement
ring, asking me to repair it. Being such an important purchase and
with such sentimental value, my instinct was to turn the job down,
but like a mug I accepted it. I took it on because the cost of the
repair by a jeweller’s shop would have been at least twice what the
ring cost in the first place. I think she may have taken it back to
where it was bought and told it wasn’t worth repairing - hence asking
me to do it - I’m not sure.
I don’t like to sound elitist but we are in the luxury goods
business and the range of worth goes from junk to priceless and this
ring really is from the lower end of the range. Apparently the fiance
was left thousands of UK pounds in his grandma’s will in order to buy
a really good engagement ring but what he picked is worth no more
than about 40 UK pounds. I don’t know what it actually cost him.
The ring is extremely thin 9K white gold, with the central focal
stone being a 1.5mm(!) round, heavily included diamond set in an
illusion setting, with the shoulders coming up to almost meet the top
of the setting and having four 0.005 ct (half point) also round and
included diamonds in each shoulder. The shank had broken right
through just under one of the shoulders so needed resoldering.
I cleaned it thoroughly in the ultrasonic, fluxed it heavily to
protect the diamonds and resoldered the break in the shank. I had to
go back into it again as the first lot of solder sort of sank into
the 9K white gold, leaving a horrible dent/pit. The second soldering
sorted it out and I just about remembered not to quench it but to
let it cool by itself. After pickling it I cleaned up the repair and
polished the ring. The problems started when I put it through the
ultrasonic prior to its final polish. One of the half point diamonds
fell out!!! Talk about stress. I wasn’t sure whether it had fallen
out whilst in the ultrasonic or whilst I was polishing it and the
missing diamond was SO small I was sure I’d never find it so I found
another tiny diamond that had come out of another ring and attempted
to set that in the hole. Cleaned it up again and put it back in the
ultrasonic keeping all fingers crossed that it would stay put. That
one fell out too (I’m no diamond setter) - so my only option was to
empty out my tank and find the thing. In the sludge at the bottom
were the two tiny diamonds and after thorough scrutiny with the
loupe, I determined which one had come from her ring. With very shaky
hands, I just about managed to get the thing sat in the hole the
right way up and very carefully mounted the ring in thermo plastic in
my vice. I don’t own a microscope so it was a case of loupe, aim
setting tool at bead of gold and worry it some, followed by loupe
inspection, worry the opposite bead, inspect, etc, etc. I eventually
managed to get all four beads (which were almost as big as the
diamond they were holding) holding the girdle of the stone in place
and repolished the ring with frequent inspection. It went back in the
ultrasonic with everything crossed and fortunately this time the
diamond stayed put!!! Hallelujah!!! Hubby just came home from work
and gave it a going over and he said he can’t tell where I repaired
it nor can he tell which diamond I had to reset - and he’s always
VERY honest when it comes to pointing out flaws - so I’m no longer
worrying about her attempting to sue me, but I am left extremely
stressed to say the least! It now looks a lot better than it did when
I took it on (not counting the break) as it’s all shiny again - but
it’s not rhodium plated as I don’t have such equipment.
What I should have done I suppose, was give her an estimate of some
kind and let her make the decision as to whether or not I should
repair it, but Hannah said that she wanted it back mended as soon as
possible as she doesn’t like being without it. I don’t know what I
should charge for such a repair. I was working on it on and off (in
between working on my daughter’s prom jewellery) for about three
hours (so maybe one and a half hours on the ring) but like I say it’s
not even worth the repair cost in monetary terms. Do you good folks
think I should charge for it and if so what should I charge - or
should I just send it back to her free and gratis so that she can
enjoy wearing it again?
I’ve bored you all enough now, so I’ll leave you in peace - while
I’m in pieces, extremely stressed and very bog-eyed! - must get a
microscope at some point - and remember to turn away such scary
repairs. Blimey, the learning curve of this jewellery making lark is
somewhat steep!
Helen Hill
UK
http://www.hillsgems.co.uk
