As for sodium bisulfate it is not listed as a carcinogen by the
IARC or any other regulatory agency that is listed in MSDS’s for
it, so I think your reasoning is lacking in a factual basis here.
I said so myself that there is no factual basis, I explained why and I said that using deductive reasoning, you cannot come up with any valid argumentation explaining that long term exposure to aerosols of sodium bisulphate is not carcinogenic.
Deductive reasoning can also lead to the idea that the moon is made
of green cheese. Tests and facts are what is needed when talking
about hazerdous substances not deductive reasoning as the real world
is as often as not counter intuitive.
I do not agree with what Jim Binnion is saying about sulphuric acid. Where do you get the idea that it is necessary for the acid to reach boiling point to become a mist?
A liquids boiling point or more precisely its vapor pressure has
everything to do with its ability to evaporate. A substances
equilibrium vapor pressure often just called its vapor pressure is
the measurement of at what pressure and temperature a substance
transforms from liquid or solid to a gas. The boiling point is
actually the measurement of the vapor pressure when the pressure is
at ambient atmospheric pressure. So a liquid that has a high boiling
point has a low ability to evaporate. H2SO4 has a very low vapor
pressure when compared to say water.
Evaporation from a non boiling surface is fairly difficult to
calculate as there are many interactive variables but it is safe to
say that liquids with low vapor pressures like sulfuric acid are
very slow to evaporate. In the case of concentrated sulfuric acid I
have seen that for health and safety regulatory compliance measures
the evaporation rate is considered to be nil.
In the case of a pickle mixture of sulfuric acid and water at room
temperature the evaporation of the acid will be insignificant. The
vast majority of what evaporates from the mixture is water. A 10%
sulfuric acid pickle is strong enough that it doesn’t need to be
heated to work so the evaporation rate is very low. So your exposure
in this case is extremely low, not zero but assuming you have
anywhere near adequate ventilation there is little chance of inhaling
any sulfuric acid vapor.
Any aerosol is a mist.
Yes so as long as you don’t do anything to create an aerosol there
is no problem, that means no spraying of the acid solution and not
quenching hot metal into it.
Long term occupational exposure to sulphuric acid mist is carcinogenic. There is no reason to think that the same exposure to mist of sodium bisulphate is not carcinogenic. The fact that it has not been tested does not prove that it is not carcinogenic.
Sodium bisulfate is a very commonly used industrial chemical, it is
highly unlikely that if it had a carcinogenic effect that it would
not have been noted and tested by now.
Given the similarities between sodium bisulphate and sulphuric acid - they are identical except for one Na atom instead of one O atom and it has one H atom less than H2SO4 -
By that kind of deductive logic you might feel perfectly safe to
drink hydrogen peroxide (H2O2) as it only has one extra oxygen atom.
James Binnion
James Binnion Metal Arts
