Hi all!
I’ve made some progress learning how to use some silversmithing tools
properly, even if I’m really not doing silversmithing with them.
For Christmas, I made my sister-in-law a hand-made bracelet. It isn’t
much, but it used a few new skills.
But she likes elephant-themed gifts and I thought I could surprise
her.
Here’s what I did.
One of the people from the Ganoksin group had sent me a sheet of
brass plate with patterns of elephants and palm trees in it.
The plate was bent and also rusted. It was also unbendable, I would
have to anneal it first.
I had the sudden idea of machining out a master pattern of an
elephant so I could cut out elephant shapes from stock printed with
elephants. I thought it as an elephant, oops, I mean elegant, idea.
I coated the plate using the Pripps Flux I synthesized from a recipe
off a link. Spraying first and then boiling off with my propane
plumber’s torch seemed to get the borate deposits cleanly on the
plate without creating worse oxidation.
I then turned off the lights, made several passes on both sides of
the plate, and then squenched in my Sparex pot.
Like an idiot, though, I had handled the plate with a steel pliers,
and then turned the other side of the plate into the Sparex bath.
Evidently even a miniscule amount of dissolved iron can plate the
metal with copper.
The plating wasn’t so bad though. There was only a tiny amount of it,
and I didn’t figure my SIL could care, in fact she might even see it
as pretty.
And the brass was now shiny after scrubbing with soap and water.
After drying, I rolled it through my rolling mill several times. It
was now only slightly warped as opposed to badly so.
Anyhow, I machined out an elephant about a square inch in area using
my CNC (breaking a pair of .03 end-mills plus an V-cutter in the
process!) for a master pattern.
I had to machine a wooden fixture to attach to my CNC table which I
could screw down the brass plate onto while cutting out my master
pattern.
But the plate was still enough warped that while some area would be
safe, others would get suddenly too deep and break the tip.
I probably should have annealed the plate twice. As it was, I broke
$24 in endmills making this pattern but I got it finished by being
extremely conservative in my passes for both depth and feed rate.
Since I didn’t want to break more end-mills, I thought I should just
cut out a set of elephants by tracing around the master elephant
template using a razor point laundry marker (Sharpie) and then using
the jewelers saw to cut them out.
I used a Dremel knife sharpening bit for deburring the exterior of
the pattern. I then used a finer grit diamond dental burr (surplus
from the local dentist) for the less accessable areas, and to double
as sanding all edges smooth.
I decided not to bother polishing. I tried a felt wheel on my Dremel
on the back of a piece of unused material with some Zam.
It made the color look like polished white metal, which was not what
I wanted.
I then used a hole punch someone else on Ganoksin had sent me, and I
punched holes for two eyes and a copper wire “tail”, on each of the
seven copies of the elephant that would comprise the bracelet.
I then found copper wire from my leftover heavy gauge #6 stranded for
grounding this summer’s electrical hookup, each of the strands equal
to about 18-gauge.
I cut two inch pieces, bent them at right angles at 3/4 inch from
both ends of each piece, and connected each piece the hole near the
tail edge, with the eye closest to the right hand edge.
My original deadline was Christmas, and I just managed to make it
albeit I was in a great deal of pain at the time. An hour later I was
in the ER for an inflamed pancreas and for passing a kidney stone.
My wife was with me, God bless her, and her compassion and concern
and love were the very best Christmas present a man could ever have.
With that, I needed nothing else.
I was also more than a little concerned for my daughter witnessing
the torture my own body was subjecting me to, but she wanted to also
go with me to the ER, and she gave me one of her cuddle blankets to
feel less lonely in the hospital I was eventually transported to.
I spent a little less than a day for observation. My wife, daughter,
and family chose to delay opening presents at my house until I
returned.
My SIL’s face lit up when she saw the bracelet. I told her, “this is
what I do for sisters”, and I got a short hug for that.
So, I haven’t soldered yet, but at least I practiced using a couple
tools necessary for soldering eventually.
Cheers,
Andrew Jonathan Fine
