CAN platinum be soldered with gold solders? I just did it 3 minutes ago on a diamond ring. Does it form a strong, permanent joint - is it PROPER? Absolutely not. Platinum needs to be worked on it's own terms just like every other metal, or else you're just another hack.
Well, there’s the matter of context. If you just did it then there
was probably a good reason to, John… right?.
Are we talking about gold soldering 19 itsy pieces of PT to make a
threestoner, or are we talking about sizing a pave eternity band?
Sometimes all you can do is what you can do. If your hands are tied
because of the situation you make a judgement call, sometimes
involving less than ‘ideal’ technique ( am I really going to unset an
inch worth of pave so that the joint can be PT welded or am I going
to 20Kwhite it with diamonds in place?) but its the outcome that
should be most important. Just make sure your outcome is actually
sufficient. Not for the sake of one’s peers, but for the sake of the
client, which eventually equates to your own sake.
Not to intentionally further devolve this but here’s an annoying
example. Lady hands me this designer piece, fancy schmancy hallmark.
VVS goods bead set in sterling (not actual bead setting, but that
cast pinpoint stuff, with lots of tiny, hard to polish recesses).
Yeah you can imagine what that looks like after a few months. She
relates how she sent it back for cleaning and the maker/seller
charged her eighty bucks, she wore it twice and its icky once again.
“Do something Neil”.
So after driving myself to distraction getting the recesses bright
and white I lacquer them. Do I like lacquer? Is this my preference?
No, my preference would be to have had the bloody thing made in white
gold and rhodiumed to begin with, made to suit the job asked of it.
Did the designer do a ‘proper’ job of it? Not in my opinion. He/she
made a determination to use a, imho, wholly unsuitable material in
such a way as to insure an unfavorable outcome. But the designer is
the one who’s got her several thousand bucks. Plus her eighty. He’s
having filet tonight, all I’ll get out of this is a mushroom
omelette.
Who has the higher standards and who has the money? Life ain’t fair.
