Well, yes, Jim. Technically that's correct and theoretical. All
platinum workers know, in practice, that a gold soldered platinum
joint will not hold even a little bit. It's like using glue....
Chuckle. Ok, John, now You’re the one slightly overstating things, I
think. Yes, gold soldered joints to platinum are sometimes not very
strong. But using higher melting gold solders, and allowing it to
“soak” a little, does give a usable joint, in many cases. If this
were not so, two tone pieces, or things like platinum prongs soldered
to gold rings, would not work.
There are some cases, though, were it becomes very difficult to get
a joint. One sometimes sees rings of gold with an outside band
wrapped around it in platinum, for a two tone band. If the outer
platinum band breaks, or is cut, or otherwise tempts one to try and
solder the two together, you can have a wild old time, because though
you get everything fitting just fine, when you heat it up to solder,
the platinum has a different rate of thermal expansion than the
gold, and gaps open up in your seam just as the solder wants to flow,
and then on cooling, not only do you have a poorly fitted seam held
in that gapped position by the solder, but then the different rates
of shrinkage can then crack the solder itself. Depends on what
solder, what alloys, and whether Mr. Murphy is watching you try and
fix the ring. But sometimes…
Just the other day, I needed to take the platinum wire prongs off an
18K yellow gold ring that was being scrapped out. Wanted the platinum
wire in the platinum scrap, not the gold. Rather than bothering to
fire up the torch to unsolder them, I figured I could just peel them
off with a round nose plier. Easy for the first two on one side, like
opening a can of sardines… The two on the other side apparently had
gotten hotter for longer, because those wouldn’t peel off at all. The
platinum broke before the solder gave way. As good as a solder joint
from gold to gold. So then I had to fire up the torch anyway to take
off those two remnants… So sometimes, you get a good joint, and
sometimes it’s not as good as it looks. The big problem for me is
simply that you can’t tell by just looking whether it’s any good or
not.
Peter
