Pallavi the bezel or collette being a little small is a correct step
provided the seat for the stone is not yet cut or added on. A bezel
can then be tapped up to the exact size and adjusted to the exact
profile on an oval mandrel, on the horn of a bench anvil, or by
pinching all around with a pair of flat/round-nose pliers.
Calculating the length of strip for an oval is quickest by treating
it as a circle. If the oval is bent into a round, the diameter of the
round will be the long length of the oval + the short width of the
oval divided by two. In your example 6 + 4 / 2 = 5. Make a round
bezel of 5 diameter and then force it into an oval. The length of
strip needed for a round of 5 diameter is D, so it is x 5
Is 22/7 or 3.14 so 3.14 x 5 = 15.7… but if you use just = 3 the
bezel will be a little smaller and can be stretched up to “fitting
size”!
Alastair
