that is not going to work, because acid would attack sharp edges
first.
Yes, if the bur is dipped directly in the acid without preparation.
But if you first clean the bur very well, and THEN apply something
that will act as an acid stop off agent just to the outer surface of
the bur teeth, the acid then acts only on the valleys. That undercuts
the worn tooth surface and in use, the previously dull edge can break
off at the undercut, giving you a marginally useful cutting edge. In
doing this, the size of the bur, and perhaps the accuracy of it’s
shape, is shot to hell, but you can still use it then to cut metal
The same method is sometimes used to “sharpen” dull files,
especially those with coarser teeth. Similarly, the above method
works more easily with coarse tooth burs. I tried it once using
simple magic marker (well, actually it was some sort of marker that
looked exactly like a Sharpie marker, but came from Radio shack, sold
as an etch stop off pen. It did work. Not all that well, and perhaps
hot worth the time and trouble, but it did, at least somewhat,
sharpen the bur.
Frankly, easier is to take one of the very thin seperating disks,
true up the edge, and use it as a fine grinding wheel to literally
sharpen the bur by regrinding it freehand. Not the carbon or vanadium
steel burs like the Busch burrs. They’re too fine a cut, and too
cheap to be worth the bother. But with some of the larger, costlier,
high speed steel burs, which have a much coarser tooth structure than
the Busch burs, it’s quite possible to return a bur from uselessly
dulled to useful. Use magnifiaction to grind the valley between
teeth, maintaining the angle. Grind the back of the tooth, not the
front leading edge. In doing this, you thin out the worn flat dulled
surface of the tooth. Take it to the point where there’s just the
faintest hint of the shiny surface that told you it was dull. don’t
fully grind it sharp. Done like this you end up with the same
dimensions and shape that the dull bur had, which might be more
accurate than the random inaccuracy you’ll get if you take the bur to
fully sharp teeth. The bur will be sharp enough to be useful again.
Slower than new, but usable. Small diamond grinding bits do the job
well also, if they’ve got a clean enough cutting edge to get into the
teeth.
Best, though, is not to waste your time sharpening your own burs
except in an emergency. Instead, put the worn (high speed, not
carbon) burs aside until you’ve got enough to make it worthwhile,
and then send them to one of the several suppliers that offers
sharpening services. What you get back are almost as good and sharp
as new, except they’re now slightly undersize. As Leonid and others
have pointed out, this is a rather useful thing to have. Bur sizes
midway between standard sizes gets pretty useful in some situations.
the cost for resharpening is much less than the cost for new high
speed steel burs, so it’s well worth doing.
Peter Rowe
