This is not a reply to the thread - more of an essay of things it’s
made me think about. I’m going to refer to this piece:
http://www.wartski.com/Koch%20brooch%20tulip.htm
It’s something I chose because it would be right at home in any art
jewelry show, and something any of you can make. While ya’ll chew on
that, I’ll start. I’ve noticed an us-vs-them attitude in jewelry,
and frankly the “Us” is the academic side, and “them” is fine
jewelry. But, you see, we are all doing the same thing. Fine jewelers
just do it “finer”. Let’s go back to music. The fundamental unit of
music is the “Interval”. That’s the space between two notes. A scale
is 8 notes, the interval between each is 1, in a major scale. “Mary
Had a Little Lamb” goes 3,2,1,2,3,3,3,2,2,2,3,5,5. Now, Jazz can be
defined by intervals, too. Jazz breaks up intervals into tiny pieces.
Instead of going from 1 to 2, it will go 1, 1 1/16, 1 2/16, etc. and
eventually reach 2. That’s called “Color” in music, and how it does
that, musically, is way beyond this thread. What does this mean?
Take the brooch above (thank you Internet Explorer 7, for tabs), make
a xerox of it, go into photoshop, and turn it into line art. It’s a
basket with two flowers and 4 leaves. Take that line art, trace it
onto a piece of sheet metal, pierce it or engrave it, and there you
have the piece that any of you can make. That’s an interval of 1 -
Mary ate a lamb. Or, cut out the individual elements, bump them up a
little, and solder them together - interval of 1/2. I could go on,
but all Koch did, and what fine jewelers do, it refine those
intervals more and more to the point of 1/1000. Why just saw out a
leaf when you can craft a leaf with gold and enamel? In other words,
why stop there? It’s also a matter of vision.
Make a cufflink out of a square piece of metal. Some see that as a
square piece of metal - I see it as 6 surfaces, 8 lines and 4
corners, all of which can be broken down conceptually into smaller
intervals, and that’s just the 2 dimensional view - the same goes for
3D - tweaking the flatness. The point I’m getting at is that people
tend to be awe-struck by the craftmanship of a piece like this -
they’re supposed to be, that’s why it’s successful. It is untimately
no different from what any of you make. It’s just that, instead of
punching out a silver basket, they said, “That’s not enough
intervals. What is a basket? It’s the body, the trim lines, the
handle, and let’s deal with each part on it’s own, and treat each
element as it’s own work of art.” In other words, let’s not just make
it, let’s CRAFT it. You can make a bezel, solder a round wire around
it, call it done and put it out the door. Or you could get that wire
and carve it and enamel it. Or you could expand the concept of a wire
into more than simply a wire in 1000 ways.
I’m not saying, Don’t just use wire. I’m saying expand your mind, use
wire because it’s what you want to do, not because it’s all you think
you CAN do. It’s the difference between simple and plain. A silver
wire is plain. A silver wire with black enamel on it is simple and
elegant. Don’t just make a trim wire, CRAFT one. Finally, I’m not
into Fractals, but they are the same thing. They come from a simple
mathematical equation that I don’t recall, but it’s simple like
E=MC2. You get a picture like a satellite shot of a river delta.
Zero in on one of the nodes, and it will blow up into the same
delta-like image. Zero in on one of THOSE nodes, and it will again do
the same - infinitely. Infinite intervals, deeper and deeper. And
lest you think I’m trying to make your work simply ornate, I’m not.
The same thing applies to simpler, more conceptual work. “We could
just get this wire and twist it into a flowing curve, like a wisp of
smoke.” But what is smoke? What is a wisp? How can we put more and
more intervals into that to make it more than just a twist of wire?
How can we CRAFT it?
Bottom line - the sheet metal basket brooch is the first level of
Fractals. The Kosch basket brooch is just 20 levels deeper into the
image. That’s really the only difference. A deeper vision. Not only
that, but each individual task - Make the basket frame, make a tulip
head, enamel the leaves, is not really all that difficult in itself.
It’s the whole, when it comes together, that seems so.
http://www.donivanandmaggiora.com
