Ok I had to go back and read this thread…Crazy gluing anything to
one’s body is insane… but if it’s your favorite method no one is
going to change your mind… if you are casting miniscule parts why
not leave the sprue on it? seems clear enough to me, as removing a
sprue is a quick snip with well maintained cutters, and a brief hit
and run with 3M’s radial bristle discs to clan and polish at the same
time…
Gloves are equally insane, again, we may all think Lee is asking for
disaster but no one is going to change his mind, and the visions of
loose mechanics type gloves are expressly NOT what he’s talking
about- skin tight driving gloves are- nevertheless, the point is each
person has their own methods. Rubber finger cots don’t work, plain
and simple, the same heat that makes the workpiece hot melts them.
facts are not trying to convince someone to change their method.
Untrimmed. Leather finger cots are about as dangerous as gloves that
are loose. a piece of leather is easily released when it gets caught
in a tapered spindle, or any other H.S. rotating equipment. 3M again
has thought of everything and makes gauzitape/vetwrap (about 3 bucks
difference per box if one buys the type for pets or the human
targeted type. both mold to one’s fingers and when doing production
tasks makes sense. It works, keeps hands cleaner, and helps prevent
calouses. If you already have callouses you don’t need the tapes!
Combine powdered Borax and liquid soap, (or melt some glycerine soap
base or bars you may have on hand in a stainless steel saucepan and
add borax to it, (about 8 oz to a 16 oz. bottle of liquid soap, or
1/4 cup to a normal sized glycerine bar) pour into a mould. the mould
can be anything from a paper cup - which can be peeled off, to a
parchment lined loaf pan which has been sprayed with either oil, or
silicone release spray before putting the paper liner in the pan) and
cut to the size bars you like, or in the case of the paper cup, once
the paper is peeled off you are left with a tapered cake of soap
that) whitens your hands, softens your skin and the borax boosts any
soap’s cleaning power. if you use unscented liquid soap, or your
glycerine soap bar has lost any scent it once had, add up to 50
minims (drops) of essential oil to the melted/liquid soap per 16oz.
Spearmint oil is emollient and actually whitens too, If you add some
food grade camphor (say two cubes worth- available at Indian grocery
stores -ask for 81 Brand fine camphor you dont want the blocks of
fake stuff) to the mixture it adds a degree of cooling to hands that
are cracked and damaged and helps boost the whitening power of the
borax too!
Wooden pliers, any number of holding devices are available. they are
appropriate for some. personally, 3M’s radial bristle discs in all
the available sizes, and types and the FX wheel have eliminated most
gadgets necessary for holding things. (i use a grs benchmate though
and lots of double sided foam tape, and setters cement). if you
haven’t tried them you may consider getting some radial bristle
discs. the small ones are as great as the 2 inch heavy duty sizes.
Canned air is not all equal. some cooling brands intended for
computers or heat sinks are chlor-flouro-methane, NOT CO2. If you
have an always on /pilot type device for your torch- you definitely
dont want to use that type. in fact even canned air is risky around
those torch lighting systems. I personally do use canned air for many
things in the studio, even cooling stone set pieces that i don’t want
to get wet. regarding water, some compounds are water soluble ( vigor
brand red rouge, wonder bar, and platinum compounds) and, yes dipping
the work in water helps in a few ways- from diluting the compound
gradually as the piece is polished/pre-polished, to instantly
quenching metal and fingers, to cleaning off polishing shapes made of
felt as the piece achieves the state you are after. Everyone that
works metal is a “real jeweler”. I have a real problem with
subjective generalizations that fly when a thread simply asking for
advice on holding pieces from a new jeweler begins- it happens too
often on Orchid. there is no “us and them”. it is all us - in
different stages of learning. isn’t that the point of Orchid.
(besides it’s function as a marketing tool. sourcing concensus
queries, and in some cases shameless self-promotion!). if we could
all learn to eliminate personalized targeting and state YOUR
experiences as you know them. …this site would be so much more
pleasant to visit.
Oh and if anyone disagrees with anything herein - or wants
soapmaking tips. please contact me off list!. . rer
