I have one that my husband bought me as a birthday gift last year - I
absolutely love it - though I am only a hobbyist at this point and
don’t use it alot - I have several different buffs/wheels and
polishes to use - - perfect for those larger pieces that you cannot
do on the flexshaft.
It has high RPM, but only 4" buffs, so the surface speed is
probably comparable to a larger lathe.
I bought one because I wanted to be able to use the 3M FX wheels,
which are not supposed to he used at high RPMs. Then 3M discontinued
the wheels, so when mine are used up, too bad.
Anyway, it appears to me to work fine across its speed range, but I
guess I don’t press hard on it, as I have not noticed any stalling.
Foredom bench lathe works well with 3M 3" radial bristle brushes. My
employees use it the most, sometimes final polish is usually done on
regular polishing unit.
3M bristle brushes are not messy, so the women like it better. Torque
is fine for 3M brushes. Probably would work okay with small diameter
muslin buffs.
Here, the Foredom Lathe does use the muslin buffs for Zam finishing,
also, have one of the course 3M buffs for quick clean up. It is
small, but powerful enough for our particular purpose. If need be can
go the basement and use the monster polisher.
I have several of the bristle 3M’s - guess I must have stock piled!
I have several of the bristle 3M's - guess I must have stock
piled!
If this is in response to my statement about discontinued wheels-- it
is not the bristle discs that are discontinued, it is the FX wheels–
they are green and look kinda like florist’s foam. I REALLY like
them… sigh…
I never heard of these, so I looked, and they appear very similar.
They come from Taiwan, and I’m guessing they are the result of
someone stepping in to fill the void left by 3M discontinuing them.
I’d love to find that they are as good (they are not cheap!) but I
won’t hold my breath.
