Does anyone know if it’s possible to take digital images and have
them converted to slides? And does anyone know of any company that
does that? Some of my work scans better than photographs and when I
submitted my big butterfly to a competition last year, I had a
horrible time photographing it, but it scanned beautifully (couldn’t
get a good light balance-either washed out silver to get flash from
spectrolite/opal or lost the flash in favor of the the silver.)
yes this can be done - I’ve had some made in the past. I guess
mainly you need a photo developer who is also digitally equipped.
check your local yellow pages for a a good quality camera/photo shop
maybe someone who also does custom developing - just in terms of a
way to narrow the field. Michelle
www.sumiche.com
creating what you want in platinum, gold and silver
Try photo finishing places - the good ones, not the cheap drugstore
type ones. There is a good one in the nearest large town to me, and
they take my CD’s and turn the photos into slides. I have been very
pleased, and gotten into shows with them. They are not cheap, but
not incredibly expensive either.
Does anyone know if it's possible to take digital images
and have them converted to slides? And does anyone know of any
company that does that?
Yes Jeanne it’s possible, and yes I’ve used a company in the US
called " Slides.com " an online site/company where you can order
slides from digital images…
It’s a great option when you really need a slide and only have a
digital image of the item, taken with either a digital camera or a
scanner. Though I believe that a digital camera might produce a
better image than a scanner, both are in digital so both should
work.
I sent 6 images taken as tiff. files which turned into 9 MG files,
taken with a friends Nikon Cool Pix 995 - 3.5 mega-pixel camera.
(Digital images when saved in tiff. are a good deal larger files
than jpeg format files.) Slides.com will also take jpeg. files and on
their website they have outline several options for sending images
to them, and a couple of methods to upload the images to them…
Uploading my images was pretty easy with a bit of telephone guidance
from the people at Slides.com who are very friendly and helpful! My
digital images reproduced to slides very well and I have applied to
several shows with them, with good result. I figure that my recently
purchased 8 Mega-Pixel Nikon Coolpix 8700 digital camera will
produce even better results.
This issue was also recently discussed in this forum in November
2003 and a search in the "Orchid Archives" http://www.ganoksin.com/orchid/archive/ in 2003 or in the November
Archives List for the thread “Digital images and slides” will give
you several companies recommended in the posts!
Slides.com seems to be one of the prefered for jury slides. Larry
Berman, a photographer, wrote up some instructions to help get the
best results. See:
The full-service photo shop I use just gave me a great tip to save
money. If you insert your digital photos into a Powerpoint
presentation (set custom page size to “slides” rather than “screen”),
the cost is a small setup ($5) and then $1 per slide. If you send
them just .jpg’s it’s $5 per slide. And then you just email them the
Powerpoint file (if you have high speed connection). I use www.centric.com in Tucson.
It’s also super easy in Powerpoint to add borders, type, or inset
photos – I used this for magazine ads and even just printed out a
24x36 poster at www.bigposters.com in New York for only $45 mounted
on foamcore!
Yes it is certainly possible. There are requirements though for
pixel density. So cheap digital cameras with low resolution will
not work. Also you need to clean up the pixels before sending it
off. The camera I currently use have a few bad pixels that I have to
go in and fix otherwise it shows up as a big white spot on the image
when its printed.
The place in Phoenix (USA) that will do this called Photo Concepts
Photo Concepts
3001 E Thomas Rd
PHOENIX, AZ 85016 - 8013
(602) 957-8055
You FTP the files to them and they convert them to slides. As I
recall they were pretty reasonable and it certainly worked well for
me. I have no idea if they will ship the slides to Norway but I
would imagine there are other places that do the same thing.
