Hi Helen, and all,
The surest way to know that there are no tight spots is to have a
little jiggle space between the stone and the bezel. The amount of
jiggle should be small enough that it does not matter if the stone
moves one way or the other, but carefull bending of the bezel from
opposite sides usually ensures the stone ends up central.
Tight spots can cause a stone to chip just trying it out for fit. I
like to have the bezel tight before soldering it to the base, that is
I know the fit is very close but the stone will not drop in
completely. After soldering I undercut the inside of the bezel (using
a ball burr or bullstick graver) to releive the tight spots and the
stone drops in freely.
I also like the stone to bear evenly on the base or ledge so that it
cannot rock when one end is pressed down. If the stone tips up when
one end is pressed then there is an overhang, or in other words a
see-saw, so by rocking the stone i see where the fulcrum is and cut
it away, repeating two or three times until rocking is barely
perceptible.
The bezel needs to be thick enough for some inside undercutting but
a thicker bezel may be too hard to bend. What I do is thin the top
portion of the bezel by filing or carefully using a rubber wheel. By
tapering the bezel thinner towards the top it will bend from the top
down rather than bend at the bottom. This is a good method for
fragile stones because I know that nothing will touch the stone
except the top portion of the bezel which can be seen. I often partly
close the bezel and then thin it some more before the final closing.
A rule of thumb for me is: if the bezel does not yield under the
pressure I am comfortable with, then thin it (tapered to the top)
until it does. This applies whether I am using a hammer handpiece or
rocker or burnisher.
The final step of getting the top edge of the bezel to touch the
stone so there are no gaps is to press the tool almost directly into
the edge, almost at a tangent to the surface of the stone where it
meets the bezel. The tool is not putting any pressure on the stone,
the pressure goes into the metal curling it down to meet the stone.
If a hammer handpiece is used for this on thicker bezels then the
edge will need trimming with a graver; if a small rounded point
burnisher is used on thinner bezels it leaves a good finish.
For bezels with no backs…
If the stone is freeform with a wavy edge of varying thickness, I
make a bezel out of a strip that is wide enough to cover the highest
spots on both sides, and thick enough to stand some thinning later on
as well as to have a strong central band around the stone. I form it
as close as possible to fit around the circumference and then solder
it closed a little tighter. A good fit is obtained all around by
hammer stretching and fine tuning with round pliers. The bezel can
follow concave spots but it must be wider there because it will have
to reach further later on when the bezel loosens up. Small concave
spots can be bridged completely.
Holding the stone centrally in the formed circle of metal I scribe
lines on the inside letting the scriber follow the contours of the
stone on each side. I trim the edges so that they swoop and curve
artistically and not necessarily follow the scribed lines precicely.
Curved tinsnips are great, or saw, then file. Eyes bales and fittings
are then soldered on and all annealed.
For the reasons described above for backed bezels I thin the edges
of the two bezels. Squeezing the two edges together with an inward
push, using flat and curved pliers, they begin to curl together over
the stone. Working around the stone a few times it becomes trapped,
and the fit around the circumference will be looser because the metal
stretches upon closing the bezels, and any concave bits will
straighten out a little. Now for some cheating! I mix 5 minute epoxy
and rub it all around inside the bezel. As soon as the epoxy gells I
continue closing the bezels by hammering all around one face and then
all around the other face a few times. I use a hammer handpiece and
have various found objects to rest the bezel (and never the stone)
against while hammering. This is important because the bezel must
continue being pinched even though a hammer is being used.
By now the epoxy is hard but mostly it has been squished inside or
outside the setting and it has done it’s job of keeping the stone
central. The bezel has been roughly closed and the stone cannot move.
I then smooth and refine the outside with files/emery/rubber wheels,
and thin the very edges of the bezels if necessary for the final
closing. For this I stand the setting on edge at an angle and hammer
downwards across the face of the stone into the bezel edges curling
the metal against the stone and closing any gaps.
Cheers, Alastair
