Although at first I resisted, I now recommend the Benchmater
system highly.
I am profoundly committed to the traditional way of making
jewelry…totally by hand, using old tools and old techniques. I
learned to solder with with a foot bellows at a European-style
cut out bench with a leather catch “net” under my solid bench
pin. I learned to sharpen gravers by hand and to seat stones
with an Archimedes drill, using burs that I made myself…the
whole nine yards. (By the way, that drill is still the most
accurate tool around for what it does.)
When Ed Friedman, our senior instructor showed me the Benchmate,
I thought it was just another gimmick created by somebody too
lazy to learn “the right way.” But he raved and I respect his
opinion so we installed one on the instructors bench. I liked it
and then I got one for my bench. Now we have them at all 15
stations in the studio and we suggest that students bring their
own bench pin.
As mentioned by others, GRS is a very innovative company that
puts out high quality products for jewelers. This versatile
system is very clever and sturdy. The different attachments
offer a wide range of station types right under your nose, where
you want them. The one and only drawback I find is that the
bench pin, because it is attached to the bracket, now sticks out
farther than I would like, but by cutting it back, its location
is improved.
I would suggest that you get a mounting bracket for each
accessory you purchase, and attach these to a board mounted
vertically along the outside of your bench or somewhere else
convenient. One gadget goes in the business position on your
bench while the others wait patiently in their brackets until
called into service.
The larger soldering station is better. The two 3rd hands are
non-recoiling and work great. You can use the ring clamp as a
soldering fixture, by installing the steel holder that is
supplied. The ring, or whatever it is you are working on, goes
in the holder and then another component, like a new prong, can
be set up in the 3rd hand and moved into contact, precisely
where you want it. Once in position, the entire assembly can be
rotated without dislodging the parts. Pretty cool!
I like the sturdy black vise that is available, and found it
especially useful for heavy duty filing.
The inside ring holder is terrific for stone setting or
florentining the outside of rings. That and the ring clamp are
sturdy enough to hammer onto. In fact, the ring clamp also comes
with a shellac plate that can hold things for engraving. When
set up the ring clamp and shellacked item can be rotated as if
in an engraving block.
I am sure that many of us have found other useful applications
for the Benchmate. I even suspect that some of you who have
found innovative new twists on old techniques are lurking
quietly on this site. Let’s hear from you with your own
discoveries.
Alan
Revere Academy of Jewelry Arts
San Francisco
e-mail: alan@revereacademy.com
web site: http://www.revereacademy.com
