You don’t solder directly in the ring clamp, as it’s plastic
line jaws obviously wouldn’t like that. But the system comes
with simple “leaf spring” type clamps, one flat ended, the other
pointed, almost like large blunt tweezers. they fit in the ring
clamp, and being thin sheet metal, don’t conduct enought heat to
the jaws of the ring clamp to harm the plastic. Not so good for
extended jobs, but fine for a retip or a sizing, etc. they have
and extension of this simple type of clamp which has spring
loaded jaws lined with transite. Occasionally useful, but by
far, most of the time I use either the soldering station held in
the ring clamp, or the larger soldering station that replaces the
ring clamp on the mounting plate. The ring clamp soldering
station has the advantage of then being able to tilt and swivel
and move around however you need, but it mounts several inches
higher up, which on some benches may be uncomfortably high up
for some people or uses. The larger soldering station has feet,
as well as a mounting plate attachement, so it can just sit on
your benchtop as well as affix to the mounting plate if you wish.
Nice system. About the only real problem I have with it, and
for me this is a significant problem, is that I do a lot of work
with platinum. Thus, I’ve replaced the steel tweezer jaws in my
tweezers with the optional carbide jaws. So far, so good. They
work well. But carbide, unlike steel, is a wonderful conductor
of heat. And working platinum, those jaws get significant heat
input. Guess what… Those tweezer handles QUICKLY get well too
hot to handle. I’ve burned my poor fingers more times than I can
count on those damnably short little handles, when I forget to
use a towel to open the tweezers. And dragging a towel around
the soldering station knocks off solder, bits and pieces, etc.
I’m so used, after several decades, to the old style insulated
handle soldering tweezers in a third hand, that remembering that
these puppies are gonna be really hot after anything more than a
minor solder job seems to not always come automatically. Why, oh
why, GRS hasn’t come up with some simple little insulated handle
for those soldering tweezers is beyond me. I finally got tired
of burns and blisters from the damn things, and made my own. I
found a bit of surplus scrap phenolic tube, fairly heavy wall,
that by happenchance was very close in it’s inside diameter to
the diagonal (corner to corner) dimension of the tweezer stock.
So a half inch length of that tube, forced over the end of the
tweezer handle, now acts as a nice and effective insulator for
my tweezers. Trouble is, I only found enough of the stuff to do
two tweezers, and I’ve a system at both my bench at work and my
workbench at home. So the home setup is comfortable, and the one
at work is still unprotected. One of these days, I gotta go
looking for more of that phenolic tube. Of get a bit of solid
bar and bring out the drills or something. Yet another project
on the back burner…
The only other gripe I’ve got about the GRS system is that I
also bought, from SWEST, one of their drop in replacement inside
ring holders that fits in place of the normal ring clamp, using
the little plastic sleeve expanding inserts to hold a ring from
the inside of the shank. Nice idea. But they’ve used an
enormous big socket head screw to drive the inserts, making it
difficult to access the leading edge of the ring, and since one
mounting position this clamp allows is edge up, this then
effectively negates much of the usefulness of this mounting
position. fortunately, I’ve another such clamp, hand held, that
uses a more sensible type of screw that happens to have similar
threads, and I can mount rings using this competing sleeve/screw
setup on the GRS handle, and then work on the edges of the rings.
Silly oversight. So was the quality control on my particular
copy of the handle itself, with didn’t cleanly fit the holder
without some sanding down. Plus, the oxide finish on the thing
apparently didn’t get completed. Was a nice dull black. But it
came off on everything. Even after sanding down the handle a bit
to loosen the fit (mostly taking off a slight roughness on the
surface), and some light buffing, the handle, which is now only
grayish with most of that patina removed, STILL leaves dark
stains on my hands. Agrevating, to say the least. All in all,
though I’d say most of the GRS system is worth owning, I’d pass
on this inside ring clamp if I had it to do over. Lotta money
for not a lotta tool. But the rest of the system is a dream.
But other than those gripes, I’d have to say the benchmate
system overall is a wonderful tool. With some nerve damage to my
left hand that limits my grip strength, the benchmate greatly
increases what I can do with that hand, and I like it a great
deal. I still don’t us it for everything. I also have, and use,
normal wood ring clamps, which for many uses, like filing up
castings and simple quick stuff like that, are still quicker and
easier for me. The bench pin attachment gets as much, or more
use, with plain ring clamps than the actual GRS one. But for
when I need that stability, the GRS system is the best I’ve
tried. And aside from the aggrevating speed with which they
heat up, the soldering station setup is also very nice, and I’ve
not been tempted to use anything else I’ve seen out there…
Hope this helps.
Peter Rowe
