Hello, my name is Kent West, I am the Technical Support Manager for
Gemvision. I am replying to Mickey Roof’s post about Digital
Goldsmith and Windows 7
ALL the software products produced by Gemvison run on XP, Vista, or
Windows 7 both 32bit and 64bit…
With Vista and Windows 7, due to fact of things they introduced well
after we released our software there are couple settings (run as
administrator or turn off UAC, for DG in 64bit run in compatibility
mode XP 32)…we have these documented out and have many, many
users running without problems (as well as most users at Gemvision
are using Vista or Windows 7).
The System6HD we have sold…and has been only camera we have sold
in last 3 years works fine in the above versions of Windows as
well…
Problem comes with users wanting to migrate older hardware (capture
cards) that were used in our older camera systems… NONE, I repeat
NONE of these cards are compatible with Vista or Windows 7…and to
be fair, many of these cards are 6-8 years old…and even older…
for computer hardware, that is fairly antiquated. Microsoft changed
the methodology with regard to how video capture was done in
significant enough ways that these cards will never be
compatible…This has often been case with hardware moving forward
to newer OS’s and will continue to be case… and unfortunately,
Gemvision is not immune to this.
I myself recently got a computer with Windows 7 and until the end of
November, there were no drivers available for the HP Laser printer
in our support department. I simply could not print to that printer.
HP had posted on their site that drivers were coming at the end of
November, and they indeed posted drivers that worked and I can now
print.
It gets even harder for 64bit systems as these REQUIRE ‘signed’
drivers…basically manufacturer has to write driver for their
software, submit it to Microsoft, and then can make NO changes to it
to get it to be able to be installed on 64bit Windows Vista and 7.
This is Microsoft’s answer to being ‘slammed’ in press for stability
problems…Part of fallout is smaller manufacturers will have hard
time trying to be able to afford to follow this, both in terms of
time and money…
Our answer to customers has never been…“Well, you’re out of
luck”…But we have honestly told them that there will be no way
they are going to get their old capture card to work on their new
computer, and even with new one, it might not give them the ease and
quality they originally were receiving…
Also, you ask if we are trying to get you to purchase a new version
of Digital Goldsmith, this is not the case, as we do not have a new
version available nor is one currently under development - version 5
is our current version.
We have a company we have referred (Winnov) that makes capture cards
that are compatible with Vista and are beginning to support Windows
7 and can be used in conjunction with older camera systems and called
by our software…We have successfully migrated customers who
wanted this, after advising them that in our opinion to keep using
their existing system as is as they get NO benefit from our software
on a ‘newer’ OS, it runs exactly same…all you get is the upgrade
problem…
Note that as the newer motherboards and controller chips were
introduced by Intel, this company (Winnov) as well has been working
out the kinks, so to speak in getting these cards to work…
Actually, there is groundswell in development and tech community for
next version of Windows to not support ANY legacy
hardware…Basically, just the latest tech and updates for the
newer stuff, this would dramatically increase stability, performance,
and ease of use (basically what Apple does…you can’t upgrade…you
just buy new computer and no ‘older’ technology (sound, video,
capture, controller, etc) will work…)
Many computer vendors still offer XP as an available operating
system. Dell still has new computers on their site with XP available
and pre-installed. You can also still purchase XP from companies like
www.tigerdirect.com ($139.99 for XP Pro SP3) and www.newegg.com
($136.99 for XP Pro SP3) and if the computer vendor you purchased
your computer from has XP drivers on their support site, you could
convert your current computer to XP.
So, I guess what I’m saying is the statement about software not
working is FALSE…
If it is referring to getting an older camera system to work on
newer computer running Windows 7-TRUE (but there MIGHT be solution
now (Winnov) or in the near future)
I invite you to call Gemvision support and we will be happy to help
you in any way we can - first to ensure that DG is working, then to
do what we can to get your camera working.
Kent West
Manager Support
Gemvision Corporation
888.357.6272
563.884.8181
