Can any one tell me why my steam cleaner smells of urine.
No, I have not peed into the water chamber before anyone asks. LOL
The steam smells awfull and is a little off putting.
Many thanks
Andrew
Many thanks
Andrew
I’ve never heard that one.
Drain it, put in some vinegar and water and get hot, then drain and
fill with fresh water 2 times.
David
Can anyone tell me why my steam cleaner smells of urine.
If you’ve used an ammonia-based cleaner in it, that might be why.
Best regards,
Lorraine
If you've used an ammonia-based cleaner in it, that might be why
Never use anything to clean your steamer. All it needs is to be
blown down once a week. Harsh chemicals can cause more problems than
they can cure.Most steamer manufacturers do not recomend puting
anything into your steamer. Also, using distilled water will help
keep the rust down.
Ron
