Hi guys!
Quick question, I’ve been working on a sterling silver curb chain and I have soldered each joint in each jump ring before I twisted the chain. Sometimes the joint breaks when I twist the chain which I’m used to. I have been finding however, when I go back to resolder the broken joint, other (non broken) jump rings solder have completely disappeared when I reheat the piece. Some of the solder seems like it’s gone, or the joint is starting to reopen just from being heated. I have never found this problem before and I’m not sure why suddenly I have to go back and resolder these jump rings that I soldered before.
I’m sorry if I’m not making much sense, but I was hoping someone out there may be able to help me figure out why this is suddenly happening.
Thank you for your time and any help is appreciated:)
Ava
