Hi Leonid:
Nevertheless, I customarily worked in with six delta tolerances,
which means 1 micron precision. So you see one has nothing to do
with another. Even a bad lathe would maintain local centricity.
One micron tolerances? .001 mm? (aka 0.00000393 inches.) Just what,
exactly, required a manual lathe to crank out parts that were
toleranced in microns? How did you go about measuring these parts? A
hand held micrometer won’t get close to that level of accuracy. The
heat of your hand will foul up the reading, nevermind what the heat
of the lathe, or the heat of cutting will do to the size of the
part. I have measured things down into the micron range…using an
electron microscope. Not something that’s going to happen in the
average jeweler’s shop. Just by way of comparison, the German digital
positioning system on my big lathe only reads to ten microns. (when
German machinists see no point in being any more precise…)
Meanwhile, he’s not entirely up in the air on this one: if the
spindle on the lathe were eccentric, but the bearings weren’t
completely trashed, he could probably hold pretty good concentricity
on the part by simply doing the whole thing in one shot, and taking
light cuts. Yes, the part would be eccentric in relation to the rest
of the bar, but concentric relative to itself, which is all that
really matters once you cut it off.
In defense of the Sherlines, they’re nice little machines for what
they are. Yes, they’re mostly aluminum, but for what people use them
for (namely small stuff) they’re enough. The nice thing about them
is that they’re small enough to pick up and put away when you’re
done, and you don’t have to rewire the house when you install them.
They have lots of nice tooling, and can be tweaked to do all sorts of
interesting things.
I don’t have one, but I’ve played with them, and have been impressed
with them. (I’m a serious lathe snob, so I can understand why some
look down on an aluminum bedded lathe, but for a beginner or for
turning wax, they’re great.) There are reasons why the lathe snobs
gravitate to heavy iron. John’s treatise on rigidity being one of
the most important, but not everybody needs to play that game. For
those who don’t understand why I have 5000 pounds of oily iron eating
up one side of my garage, the sherline’s one of the best options out
there for a new micro-lathe.
For normal mortals, 0.001" is plenty good enough for jewelry work.
FWIW,
Brian
