hi all
can anyone recomend a good casting torch to use with oxy/propane for
general melting and casting
thanks
jason
hi all
thanks
jason
can anyone recomend a good casting torch to use with oxy/propane for general melting and casting
I would recommend the victor torch with a rose bud tip for melting.
The best thing to do would be to go to welding store and get a
complete kit with regulators.
The Victor has many available tips. Mention you will be using oxy/
propane and that you want flash back arrestors on the torch and the
regulators.
Daniel Grandi
http://www.racecarjewelry.com
I would recommend a Harris Calorific made in Ireland. It uses a
multi- port (rosebud) tip. Let the supplier know what fuel your
using.
