A company here in Dallas, The Mineral Hunters, takes similar items
and turns them into oversized display pieces. He mounts them on
appropriately sized bases, cleans and polishes the
bolder/rock/specimen to his liking and gets paid handsomely for his
efforts. His clients include interior designers who are always on
the lookout for something different for people with homes or offices
with large spaces to decorate. Mind you, his finished pieces are
definitely worth their asking prices – he really is good at what he
does.
Yes I did once, but I used Betonimit, from these guys http://www.crowdersupply.com/ to break down the boulder. Took a day
and broke it down to about 80 lb pieces. There are a couple of
manufacturers of similar material and they will all break a rock in
short order without fractures except in the areas between the holes.
On mine though it weighed about 4 tons and turned out to be worthless
about 3 inches in. Glad yours turned out better. Want to part with a
few pounds?
well, first you might consider using a bail to mount it on a chain
rather than trying to drill a hole for a jump ring. then look for a
very large customer.
Took a day and broke it down to about 80 lb pieces. There are a
couple of manufacturers of similar material and they will all break
a rock in short order without fractures except in the areas between
the holes. On mine though it weighed about 4 tons and turned out to
be worthless about 3 inches in. Glad yours turned out better. Want
to part with a few pounds?
This looks like an interesting material, it seems to be like
drilling a blast round, except without the dynamite.
There is another mining technique, called pre-splitting, that uses
primacord and drilled holes in a sequence. Presplitting can produce
a finished surface over a 100 foot granite wall; with care,
accuracies of +/- 2 inches can be achieved. however, it is a blasting
technique, so do not try it at home.
