Using Titanium Scissors on Silver Sheet?
I have a titanum sicissors that works great on silver sheet, 24 ga.
I just have a question about the scissors, cutting boards, do they leave a flat edge or slightly bent?
N. Katsu
I have cut bezel strips which curl in a pretty spiral. As others said, the metal wants to curve, so a permanent marker stripe on the metal with a scribed line to follow with the scissors helps. Sanding required, of course. The titanium scissors also cut snippets off corners, wire lengths, etc., and are from the sewing area at Walmart.
