All;
Please be a bit more international? … Ganoksin has the online solution…
Use our “Online Units Conversions Utilities for Jewelers” - Free as usual
[] http://www.ganoksin.com/MetalCalc/area.htm
Support: Square meter, Square centimeter, Square millimeter, Square foot,
Square inch.
[] http://www.ganoksin.com/MetalCalc/circular.htm
Support: Circumference, Radian, Degree, Grad.
[] http://www.ganoksin.com/MetalCalc/weight.htm
Support: Metric: Kiloton, Tonne, Hundredweight, Kilogram, Newton, Gram,
Carat, Milligram, Avoirdupois (U.S.): Long Ton, Short Ton, Long
Hundredweight, Short Hundredweight, Stone, Pound, Ounce, Dram, Grain,
Troy: Pound, Ounce, Pennyweight, Carat, Dyne, Grain,
Apothecaries: Pound, Ounce, Dram, Scruple, Grain,
[] http://www.ganoksin.com/MetalCalc/length.htm
Support: Metric: Kilometer (km),Meter (m), Decimeter (dm), Centimeter
(cm), Millimeter (mm). British And American: League, Mile (mi), Furlong
(fur), Chain (ch), Rod (rd), Yard (yd), Foot (ft), Inch (in).
[] http://www.ganoksin.com/MetalCalc/pressure.htm
Support: Metric: Pascal, Milibar, Kilopascal. Bar. Mercury: Inch of
mercury, Centimeter of mercury, Milimeter of mercury.
Other: Pound per square foot, Pound per square inch (psi), Atmosphere.
[] http://www.ganoksin.com/MetalCalc/temprature.htm
Degrees Celsius, Degrees Fahrenheit, Degrees Kelvin
[] http://www.ganoksin.com/MetalCalc/volume.htm
Support: Metric: Cubic meter (cu m), Hectoliter (hl), Decaliter (dl),
Liter (l), Milliliter (ml), Cubic centimeter (cu cm), Cubic millimeter (cu
mm), U.S. Liquid MeasuRe: Acre foot, Cubic yard (cu yd), Barrel, Cubic
foot (cu ft), Gallon (gal), Quart (qt), Pint (pt), Gill (gi), Fluid Ounce
(fl oz), Cubic inch (cu in) Fluid dram (fl dr) Minim (min)
U.S. Dry MeasuRe: Cubic yard (cu yd), Barrel, Bushel (bu), Cubic foot (cu
ft), Peck (pk), Gallon (gal), Quart (qt), Pint (pt), Gill (gi), Dry Ounce
(dr oz), Cubic inch (cu in), Dry dram (dr dr), Minim (min),
British Imperial Liquid And Dry: Bushel (bu), Peck (pk), Gallon (gal),
Quart (qt), Pint (pt), Gill (gi), Minim (min)
The index page can be found at:
http://www.ganoksin.com/MetalCalc/index.htm
I hope you will find these utilities useful, and don’t forget to bookmark the page.
Hanuman
Your Host
