Does anyone know of a supplier that might stock 6mm sterling silver
cube beads, Preferably in the UK. Only small quantity required.
Thanks in advance,
Neil
Thanks in advance,
Neil
Does anyone know of a supplier that might stock 6mm sterling silver cube beads, Preferably in the UK. Only small quantity required.
how about The Bead Shop in Covent Garden, London
best wishes
Judy
Hi Neil,
This company sells a 6mm sterling silver cube bead, diagonally
drilled:
http://www.spoiltrottenbeads.co.uk/sterling-silver-beads-13-c.asp
Alternatively, if you wanted them straight-drilled, could you
purchase 6mm square sterling wire and cut and drill your own? Not as
simply as buying them I know. I couldn’t find any more, other than
the link above.
Helen
UK
http://www.hillsgems.co.uk
http://helensgems.ganoksin.com/blogs/
I make all my own hollow silver cube beads. I get different sized
square tubing, cut them to the sizes I want, solder a silver square
disk at the open ends. I am careful to drill holes before soldering
for gases to escape I prefer to drill the holes through the square
tubing, as I can get them more perfectly centered. Sometimes I want
the holes in the center of the bead, or sometimes closer to the top
of the bead. Easy to do.
Alma Rands
