Silver is a wonderful heat conductor, one of the best, so the water
will drain away the heat at a prodigious rate.
This actual job has been covered, I think. I’m with Don in SoFl -
take it out. I don’t use an Exacto, I use a bench blade (dull pocket
knife), which is more stout. Crack the seam and then once around and
it will fall out.
The larger topic soldering with a heat shield is useful, though.
Peter is right in the quote above, sort of. Silver is THE most
conductive metal, second only to carbon. Looking it up, quickly -
it’s in k (W/m K) but it’s the ratio of the numbers that matters,
here.
Graphite is 1950 (k (W/m K), silver is 429, gold (24k, I guess) is
317. Stainless steel is 14 and concrete is .05-1.50. Even aluminum is
only 237. That means that silver conducts heat almost twice as fast
as aluminum, and 3000% faster that stainless. That’s a lot.
Somebody else mentioned using wet sand or something. We use spent
investment, which we have, and wet it. In a melting dish, which is
cheap. It holds both the piece and the water. I weld platinum rings
with the diamonds buried in it, every day.
But the bigger the silver ring, the more it becomes a monumental
battle against the cooling effects of the water, and eventually it
just becomes practically impossible - the torch/flame gets so big
it’s just not practical.
I’m completely capable of doing this job with the stone buried in
wet sand, but I wouldn’t. I’d remove the stone and the whole
headache just goes Poof!!
