Tumbling shop made jump rings!
Hi there!!
I am making oval jump rings. I am planning on tumbling them after I get them done. My question is? Do I close them down tight where the cut is, so it makes a continuous loop, then tumble them. Or leave them open and just tumble them.
Thanks,
Lary1047
Close them and string them on a bit of plastic covered wire. Makes it easy to extract them from the shot.
Cheers,
Karen
If you tumble them open you will dull the cut edges a little. Might be an issue if you solder some of your jump rings… Don
Good Morning everyone!!
Thank you Karen and Don!
Just finished closing all of them and strung them loosley on small plastic zip ties. They are headed for the tumbler.
Thank again for all the suggestions and ideas.
Lary1047
