Hello all,
I read a lot of remarks about tumbling in the archives but I still
have a last question.
This is what I would like to do: After sanding, smoothing my pieces
(14k or 18k gold, maybe platinum) and giving them an intermediate
polishing step I would like to work harden them by tumbling them with
stainless steel shot in a rotating barrel. Do you think it is
necessary to give tumbled pieces a last polishing step to finish
them? Do I loose the hardening effect when I polish my pieces with a
very fine grit?
I will appreciate any comments, I really enjoy reading the posts on
orchid.
Matthias F.
www.matthiasfehlinger.de
I have watched videos and read different articles about polishing sterling silver jewelry, but I am wondering if there is a stepped process that works better than others. Originally, I just tumbled pieces in steel shot, but later read that this method just burnishes them. So then I read that using a buffing motor was best. At the moment, I am trying to figure out what works best and wonder if anyone has the definitive answer! I make the piece, file, sand to ultra fine, then put in the tumbler and then use the polishing motor with Tripoli and Rouge. At this point, it seems the Tripoli takes all the burnishing off, so I wonder if this is the correct step after burnishing. Should I use the buffing motor and then the tumbler? I am trying to get the best high shine that will last. Thanks in advance for your consideration.
Emily
Once silver is hard, it stays hard unless you anneal it again. You can also heat harden silver in a kiln or even a toaster oven at 550 degrees for 60 minutes. As for finishing, it depends on what final finish you want. I always do a high polish even if the finish will be textured. This way you find any bad spots that might show through the texture. Once fabricated, and depending on the piece, I go over it with a medium EVE wheel to shape and remove scratches. Then I go straight to tripoli and then rouge. If you have a lot of fire scale, that needs to be removed first. I have a compound from Devine Brothers in Utica NY that is very aggressive at removing fire scale. If I am using recycled scrap that I have rolled out, it will definitely have fire scale. I remove it from the larger sheet before I cut it up to make whatever I am making out of it. It is a lot easier to remove fire scale this way than after the piece is finished. You can also find bad spots this way and avoid them when you cut up the sheet. I tumble smaller pieces like ear wires and little earrings in SS shot or a pin finisher. Tumblers also work well to clean up pieces that are shop worn. Be careful of soft stones. Read Judy’s book on tumbling. Lots of good stuff there. Good luck…Rob
Thanks Rob. What is an EVE wheel? Is there any point in using the tumbler after using tripoli and rouge?
Emily
Eve is the manufacturer. Go to Rio and do a search. Generically, they are rubber abrasive wheels and there are several manufacturers. I just buy Eve because I know that they will do what I want them to do. There are times that a tumble after tripoli might make sense if there are places on the piece that tripoli on a wheel can’t get to. You won’t get the same finish as tripoli, but you will likely even things out a bit. Take a look at the discussion about ultrasonic polishers. You may also get some ideas there. Good luck…Rob
Thanks again Rob. I looked at Eve products at the Rio website. I have some similar to these. As for fire scale, i try to prevent it with a slurry of denatured alcohol and boric acid.
Emily
Sounds like you are doing all the right stuff. I use a lot of denatured alcohol and boric acid to prevent fire scale. I keep it in a large mason jar that I can easily seal. It is a pain to remember it, especially when you are only annealing. For me it works well after I have pre-polished a piece and only have to add a jump ring or some other final piece. I am typically using easy solder at this point, but occasionally medium solder. …Rob
Eve are fantastic. I just loaded up on lots of stuff from them.
I pickle with citric acid and distilled water warmed in a beaker on my coffee warmer. Loving it far more than boric acid pickle. I also light my piece w denatured alcohol on it and let it burn down before soldering.
