Hi,
i was just wondering…what is your goal for the tumbling process?
it is such a broad category…what are you wanting it to achieve?
what type of tumbler are you using? (rotary, vibratory, magnetic, etc), ?
and what type of media are you using? (steel shot, plastic, steel pins, porcelain, shell, etc)
on a side note, long, long ago, while researching tumbling machine options, i stumbled upon a great video…it was embedded in a mass finishing website…i did not save it, and am sorry i did not!
it basically discussed rotary tumbling, and what dynamics are in play, and how to achieve the best case scenario of media movement for the best results…
it talked about the barrel fill needing to be 50%
(and i found it odd that many smaller tumblers are sold with a motor capacity weight rating lower than what was needed to fill the barrel 50% with steel shot…)
basically the goal is to achieve a perfect sliding S wave motion of media…enough to maximize media movement/ efficiency, while reducing the potential for “part on part” impingement…
(of course, the number of items being tumbled relative to barrel/ media capacity is important to determine…)
the media rides up the side of the barrel and then slides back down (as high as possible without passing the point where media “rains down” versus sliding back down) i think this is a function of barrel rotation speed(?) and needing barrel walls that are flat sided (like a hexagon) rather than smooth.
anyway…i thought it was a great video and i wish i had saved it! if anyone recalls a video like this, please post it, thank you!
julie
