use Microbrite porcelain balls as a burnishing compound... Or should I lose the 1mm balls?
Brian, I’m not familiar with the Raytech, but I suspect that if you
don’t use the 1mm balls, the burnishing effect will not go into
corners and other small areas. You might try simply closing off the
filter aspect of the tumbler, if that’s possible, and let your
jewelry burnish in a closed environment.
Just a thought.
Judy Bjorkman
