Does anyone know a company that will bronze baby shoes?
Do you know where we could get the equiptment?
Do you know what it takes to do this?
If you know any of this e-mail me at @ROB_LIDDICOAT
If you know any of this e-mail me at shearob@nanaimo.ark.com
Don’t know of any companies (I am sure there are numerous ones out there)
but the process used is electroplating. The ArtMetal list had a long
discussion on this so you might want to contact the the server and check
out the logs and also the resource list. Info below as to where, what and
how.
John
Here’s the computerese:
index [archive | path-to-archive] [/password] [-all]
Get a list of files in the selected archive, or the master archive if no
archive was specified. If an archive is private, you have to provide its
password as well.
get <archive | path-to-archive> [/password] [parts]
Get the requested file from the specified archive. Files are usually split in
parts locally, and in such a case you will receive the file in multiple email
messages – an ‘index’ request tells you how many parts the file has been split
into, and their sizes; if you need to obtain certain parts, specify them as
optional arguments. If an archive is private, you have to provide its password
as well.
Here’s an example which I actually used (and it worked):
get theforge log9608
log9608 means the digest for August, 1996. Be careful not to put a
space between log and 9608.
Here is (I think) what you want to send:
get ARTMETAL log9608
except that you will need to figure out which log you want. You do
that with the index command, like this:
index ARTMETAL -all
IMPORTANT NOTE:
Don’t send these to the email list; use a different address:
listproc@wugate.wustl.edu
Be careful with the spelling; you’re corresponding with a computer
with zero imagination. If it doesn’t work, write me.
John Dach and Cynthia Thomas
Maiden Metals
a div. of True greatness may be found in the
MidLife Crisis Enterprises humblest places.
PO BX 44
Philo, CA 95466
707-895-2635(phone/fax)
@John_Cynthia_MidLife
