Hello can anybody tell me what are the most important tools to have
in a jewelry repair shop? I want to buy some tools but I need someone
to tell me the most important tools to have. Thank you. Alberto
Tools,eh? Apart from “needing customers”, the most important thing you
might need is a decent, good working rolling mill. The next piece of
apparatus is a polishing machine that has a strong suction, ( for
health reasons). In the bottom of the sink you could look into a
“jewellery retrieval unit” to capture any dropped jewellery items that
were accidentally dropped down the sink. (not as important! but it
helps.) A good dependable (heating and timer controlled) “ultra-sonic”
cleaning machine, a strong steam machine / with 40 lbs.+ pressure. I am
sure now lots of ‘our’ friends can chime in with their other
suggestions! “gerry, the cyber-setter,eh!”…
www.gemzdiamondsetting.com
First of all, you need a properly designed bench and a comfortable
chair, you will be spending a lot of time sitting at your bench. And
good lighting. A combination of incandescent and fluorescent works for
me. The general process for repairs includes:
setup or preparation of the item to be repaired, can include
cleaning, reforming, and making fixtures to position the item -
the repair process- usually soldering, sometimes remaking or
replacing parts
3.clean-up and pre finishing the repaired item
- polishing, final cleaning, and protective packaging of the
repaired item.
The major items you need are a gas-oxygen torch and accessories; a
flex shaft or micro motor and abrasive wheels and bits; a collection
of hand tools such as pliers, files, mandrels, mallets and hammers; an
ultrasonic or other cleaning system; and a buffing machine.
Almost every jeweler I know has a collection of favorite tools that
are distinct and different from anyone else’s tool collection. What
you use and how you use your tools is a matter of training and what is
available. I am still collecting tools as I need them after 30 plus
years at the bench.
Good luck
Rick Hamilton
