Hi Brent, I have taken black and white images to my Cad Cam
specialist with my specs for the height of any raised areas and the
depth of the overall piece. In your fingerprint piece, maybe I would
submit the exact size of the fingerprint with the lines of the actual
finger tip print to be raised 1mm. off the surface of the print. The
negative spaces left of the print would be the (dime-sized?) surface
of your charm which is a thick as you want it to be. Hope this is a
clear picture… best of luck.
June of @Rjtwin
