Hello,
I am trying to etch a piece of flat sheet 14K yellow gold, and my
first attempt was somewhat of an expensive failure. I read through
the orchid archives on this question, but I could use some more
specifec answers.
What is a good resist to use? I used asphaltum, and it didn’t
hold up perfectly to the acid. -
Is it better to use aqua regia concentrated, or diluted with
water (if so, what ratio?) -
Should I use a magnetic stirrer and float the piece upside down
in the etching bath, or is there another method? -
Should I add heat (if using the magnetic stirrer)?
Thank you SO MUCH,
Wendy
