The Polishing & Plating of Metals by Herbert J. Hawkins, 1902
The Polishing AND Plating of Metals by Herbert J. Hawkins, 1902
A Manual for the Electroplater, giving Modern Methods of Polishing,
Plating, Buffing, Oxidizing and Lacquering Metals, for the
Progressive Workman.
This 1902 book is a huge volume, 358 pages of solid information
(this edition was published 1904). The author begins with a
discussion of specialization in the plating world, and how this
leads to problems if people change jobs. How much better if a person
understood and could practice the whole spectrum of plating. The
only way at that time to get a full understanding was to work in
different shops, even staying just a few months before moving on.
This book is an attempt to supply the eager workman with a
compendium of the field, a full education in a single place.
There are many illustrations, photographs and diagrams in this book.
Note that the sections at the end, on silver and gold plating, on
metal coloring and patination are excellent.
This review is longer than usual as a result of the amount of
in the book.
The author criticizes existing books on plating as being either
chemistry texts informed by laboratory experiments and not
practically applicable or compilations of practical experiences
which while useful to a very knowledgeable person who can
discriminate and discard useless or dangerous recipes are
nevertheless full of mistakes (compounded by accumulation and
repetition through time) and bad practice. This book seeks to
address this. He notes that current practice accepting new ideas
takes about ten years.
The book begins with a discussion of health and safety, or rather of
what being a plater meant then. For instance, with little glove use
he discusses the variance in how people’s hands are attacked by the
cyanide solutions. Nasty stuff, and a real reminder of what you deal
with in plating, and how far we have come in understanding, and
safety equipment. The health problems are described in gruesome
detail. It is clear that dermatitis, boils and other symptoms were
considered an everyday occurrence and simply part of the job. For
instance platers are recommended to take a steam bath once a week,
and to notice that there is a distinct smell of cyanide in the
sweat, thus proving that upon exposure it enters the body. And so
on, with a very cowboy approach to chemical exposure. The
descriptions of the woes and results should have scared off most
reasonable people. Wow. There are recipes for skin creams including
‘skin food’ to heal the skin.
Next is a great chapter on polishing, its importance in metal
preparation and shop layout issues. All sensible and smart.
Incredible engravings of machines and equipment are there to
accompany the text. There are many many illustrations and engravings
in the book. There is a really wild early flexible shaft for
grinding castings that looks like a recipe for entanglement
adventures. Emery wheels were made in different ways by combining
emery with cements and these could explode, the author saw a chunk
of every wheel go through a twenty inch thick brick wall. In fact
these are a kind of grinding wheel, but in finer grits than normal,
and used for sanding operations as well as more coarse removal.
There is a good description of using a grinding wheel dresser to
smooth a wheel.
There is a scary story of how to remove splinters of metal embedded
in an eyeball using a horsehair bent into a loop which is dragged
over the surface of the eye until it catches on the splinter
allowing it to be suddenly yanked out. I actually have a similar
tool made from thin fishing line that I got in Germany from a die
sinker. Really makes you want to wear safety glasses.
A section on making your own buffs makes the point that the canvas
discs used should alternate directions of weave to make the buff
last longer and work well. Making wooden wheels is covered, with
leather coverings. The number of details of buffing and polishing
are enormous and intense and lets you realize how much simpler life
in the workshop is today for a jeweler. There is an extensive
description of different polishing compounds, how they are made and
used. Tumbling is addressed, and one interesting tidbit is that the
shape of toy jacks were originally ‘jackstones’ and were a tumbling
shot shape for getting into hollows when tumbling steel castings.
Oddities include tumbling barrels with holes in them running in a
bath of soapy water, all metal and dust removed ends up outside the
barrel in the easily changed pan of soapy water, and using small
scraps of dry leather as the tumbling media to get a bright finish
on small parts, or that tumbling barrels that are bigger in the
middle than the ends are much faster at finishing than straight
sided ones.
A chapter on acids and pickling solutions follows. The absence of
plastics is noticeable, as in pickle barrels made of wood coated
with asphaltum, in fired ceramic stoneware baskets for hanging work
and more. The author concentrates on iron castings and cleaning them
before going on to describe other metals. The is very
thorough, but predates the use of salts that dissociate to form low
dilutions of acids for pickle solutions. Many of the recipes would
be seen as dangerously strong today.
Satin finishes and dips for producing those surfaces are described.
Ormolu dips as well, which produce golden yellow finishes on brass,
to be lacquered or plated. Wooden shoes with two inch thicknesses
are recommended as the floors of plating shops were often wet with
water and mixed chemicals. Nasty working conditions.
The layout of shops is dealt with, the plumbing and flooring types
and considerations. Basements are recommended for plating shops.
Cement tanks are suggested, and their building is exhaustively
described. Rammed concrete was used at this time. Lining of tanks is
fully described. Steam was used to heat solutions and so steam
generation and handling is addressed.
Dynamos and electricity generation, machine building, wiring, and
more is dealt with. Some of the large generators pictured look quite
frightening. All the connections, meters, controls, bus bars etc are
pictured and described.
There is a burning call for scientists and platers to research and
compile tables of current densities and metals, which all now exist,
but at the time were lacking. This book however does give some
detail for this.
The chapters on gold plating and gilding are especially interested
and thorough. The recipes for gold and gold alloy (and colors such
as red or green) solutions are really interesting. They are fully
detailed for making solutions from scratch. Solutions and methods
for gold plating without electricity are described.
Silver plating is equally well addressed, in great detail. Lots of
recipes are given. Further extensive chapters deal with nickel
plating, copper plating of all kinds, brass plating and all its
subtleties, bronze plating (I have not seen this addressed
elsewhere).
The chapter on burnishing is very intriguing with many illustrations
of shapes and types of burnishers.
A great, very large chapter on metal coloring and patination has
many recipes in detail. A unique one is to use a very old liver of
sulfur solution with a lot of ammonia which give a greenish tone on
silver. There are dozens of recipes, all kinds of reds, greens and
other colors on metals. A number of painted on colorings are
described.
A final chapter on lacquering is a fitting finish for the book. Very
well described and detailed.
So, if interested in plating, metal coloring and patinas this book
is a must-have.
File Size: 41.5MB, 358 Pages
Download the full eBook at the ridiculous price of $5.
interesting…i have been getting sporadic tinges of curiosity about gold plating…pen plating…etc…
want to research about the chemicals used…safety…etc…
julie
