if photographic style was not a factor then why did you pay money
to have your jury slides critiqed ? Noel, i would like find some
one on this list who can discuss three rather broad specific
questions #1 color combinations for the jewelry and the background
Example would be a black pearl set in silver on a ______ background
Black, white, or medium gray all will work, each conveying a
different “mood”. What is critical is that the lighting must be
controlled so that the edges of the piece do not “merge” with the
background. Shiny objects reflect their surroundings, which is why
the background should usually be physically separated some distance
from the piece (piece on glass, some distance above or in front of
background) when being photographed. If using film (slides), what
you get is what you get, you’re done. If using digital, one can
replace the background quite easily, given the proper tools and
skill.
Of course, a slide can be scanned, converting it to digital, and the
needed or desired manipulations can then take lace. It is also
possible to make a slide from a digital image, but why?
What I glean from the conversations here is that jurors are looking
for quality and consistency in the photography as opposed to a
hodgepodge of colored backgrounds, shooting angles, high key vs low
key, etc. Making a subject “pop” from the background is probably
helpful, psychologically, and that is done through control of
lighting and choice of the proper hue, tone and saturation of the
background or gradient.
shadows no shadows direction of shadows ?
If backgrounds are added and shadows are desired, they will have to
be drop shadows, obviously. Size, color and intensity of drop
shadows is subjective, and does affect apparent “depth” of the
image. Direction is controlled by the lighting; the direction of
drop shadows should never conflict with the direction of the primary
(not fill) lighting. IMO, id perfectly flat lighting has been used,
shadows appear un-natural…to me. In that case a circular
gradient always seems more appropriate. Beware of the shadows that
result when shoting a piece directly on the final background. they
can blend with the image and kill that “pop” you MAY be looking for.
For tall objects, a backlight is used to separate the object from
its background. This gives a tiny rim of “highlight” and lets the
object jump forward. Barn doors and gobos are used to control spill
from the backlight, unless it is a tight spot light with a snoot.
if the photos are meant to determine quality Reality check here is
this there is no conspiracy... i do not believe you can find three
jurors who dont know each other to agree on how to compose a good
jewelry photo. think about this,, if there is no agreement
on,,what color combinations to use? or how to light and use or not
use shadows? textured background or not ? why spend lots of money ?
second, if a show has one space open why should the promoters not
disclose only one space is available before solicitation results
in say 850 entries at $45 a pop and no refunds ?
Hard to comment on that, but I suspect there need be no
agreement…just consistency and good photography. Again, it seems
a little unfair to me to expect a craftsperson who has attained
demonstrable skill in one craft, to now gain skill in another…or
have to pay the heft costs of professional photography in order to
have a chance to sell their work. Again, it’s just my opinion, having
been there and done it, that it is much more profitable (isn’t that
the goal?) to find a good agent or work with retailers who are
willing to BUY your work. It takes work and effort to find them, but
this jury thing seems to be a world of work and someone is STILL
reaching into your pocket. And how does the skilled, but short-of-$$$
person get in?
Wayne
