Has anyone heard of this new implosion hydrogen torch? You’re supposed to
be able to solder metal to glass with the thing, other than that I don’t
know who’s making it …Dave
You’re talking about the Brown’s Gas Machine. It’s currently made in
China and being distributed by one company in the U.S. I’m ordering one
if I can swing it. I’ll reprint a little of an article I have on it.
Professor Brown developed a stoichiometric mixture of hydrogen and
oxygen taken from water that is mixed without causing an explosion,
hitherto thought to be impossible to do. He has made another state for
water besides ice, water or steam. It is Brown’s Gas!. One liter of
water makes 1860 liters of this gas. When a spark is added to the gas,
it still does not explode, it implodes. Brown’s Gas is the only
substance that impodes. When it implodes, it make the most unique welder
in the world. Peo who weld can confirm that it is impossible to weld
dissimiliar metals, glass to metal, metal to brick, and just about
anuything to anything, but you can with a Brown’s gas welder. The same
pumpkin colored flame can weld two pieces of aluminum together at 900
degrees F (even if you are not certified to weld aluminum which usually
requires a lot of skill). The same flame can braze copper at twice the
temperature (1800 degress) or put a hole in brick at twice that
temperature. This same pumpkin colored flame can sublimate Tungsten at
over 13,000 dergrees F. As a matter of fact, it can become the
temperature of the sum (8000 degrees C)…
end of quote
this is pretty amazing stuff, I have thought of so many uses for this
emerging technology it stuns me. Automobile engines for one, the car
that runs on tap water… imagine it!
I’ll let you know when I receive more info, my contact has not yet diven
me the name of the distributor. The quote is from the Good News
Newletter.
Jeffrey Everett
Handmade 18K and platinum gemstone jewelry. Fine die
and mold engraving. Diamond setting. Class rings/pins.
25 years experience in the jewelry trade. 515-472-9830
end of quote
Newletter.
Jeffrey Everett
did you know that your phone # is know longer listed. It sounds like an
artists dream.
artists dream.
Yes, I recently changed the phone number but I forgot to update my sig
file.
Thanks for bringing it to my attention.
Jeffrey Everett
Handmade 18K, 22K, and platinum gemstone fine jewelry.
Diamond setting, rubber/metal molds, casting, lapidary
Die and mold engraving, plastic patterns for casting.
Cad jewelry design, cad/cam milling scroll filigree…
P O Box 2057 Fairfield IA 52556 515-469-6250
