would leather stamps work? these are available in all kinds of
shapes.
Yes, leather stamps do work. My students have used them on
copper in the classroom. Obviously, anneal for best results.
Carole
Leather stamps will work ok if they are steel. You should
probably heat temper the metal before using.
Cheers
Virginia Lyons
That’s a big yes! Also… try using a big, ugly, nasty, rusty
piece of steel… or chunck of rail road rail. You need big,
deep sharp pits. Hammer your silver sheet on there for a
’hammered’ texture. Clean the loose rust off the steel with a
wire brush. Hammer, then cut your silver… tumble… beautiful!
Have fun, Red
The steel may not be harnened so the stamps my lose their
definition after a wee while. Rather, buy hardened steel stamps
from Thunderbird Thunderbird http://www.tbscorp.com/ ph +1 505
722 4323 or 1-800-545-7968 ext 17.
I just discovered them. Nice range of stamps.
Brian
B r i a n A d a m J e w e l l e r y E y e w e a r
brian@adam.co.nz ph/fx +64 9 817 6816 NEW ZEALAND
http://www.adam.co.nz/ Wed 04th August 1999
I haven’t seen this yet, so I’ll bring it up. Instead of
torturing your beautiful sterling silver, you can punch, pierce,
hammer, burn, etch, or doodle a pattern, on a similar sized sheet
of copper or brass and roll them together. (annealed, of
course). Frances
Visit me or “beam me up” at:
http://members.toast.net/frangro//index.html
