I can’t find a tapered spindle for a 1 / 2 inch threaded shaft
on a 1/ 3 horse bench grinder I wish to use as a buffer. Rio has
a picture of one that might work but at $25 each one on each end
would be more than the grinder is worth! All the spindles I find
are for non-threaded shafts. Any suggested sources??
Bob
You?re probably looking for trouble ordering threaded spindles
sight-unseen. Thread matching is tricky at the best of times-
remember that you must match the number of threads per inch as
well as the thread diameter. If the grinder was fairly cheap,
then do as I did a month or so ago- slice the threads off the
shafts by holding a hacksaw blade against the base of the thread,
motor going. Dangerous, but fun… I secured my non-threaded
spindles by filing a small flat at the point where the grub-screw
made contact with the shaft. You could even tack-weld or braze
the spindles on if you are really worried.
Regards,
Laurence Veska
has a picture of one that might work but at $25 each one on each
end would be more than the grinder is worth! All the spindles I
find are for non-threaded shafts. Any suggested sources??
Regards,
Laurence Veska
Greetings Bob
I had a polisher motor burn out on me and went to a heavy duty
grinder unit. I could not get threaded tapers to fit and only
one’s to fit the shaft are ok. About 5/8 in from the end that
goes on the shaft drill two holes at right angles to each other
and thread them. Place the taper on the shaft at the position
that you want it and scribe through the holes onto the
shaft.Centre punch the centre of the holes and drill the shaft
the diameter of the size screws that you have threaded the holes
and to a depth to where the drill starts to drill it’s full
diameter. Fit the taper to the spindle to the shaft and in a
position to see the two drilled holes. Hold in place with grub
screws (allan key type) and only long enough to go down into the
drilled hole and level with the top of outside diameter of the
tapered spindle.
The reason of two screws at right angles is so the each is a
holding force against the other. One screw would soon loosen up.
An added security would be to use some (Locktight) but should you
wish to remove it at some time you would need to heat the tapered
spindle to soften the bond between the two. The main reason for
drilling the shaft is so the the screws do not raise a burr on
the shaft and pick and seize the spindle on the shaft.
Hope this is of some help Bob.
Best wishes
Major @pyramid
