I have made some simple necklaces-- round beads strung on silk. And
some of the necklaces always snag and catch in my hair. Some don’t
tangle at all. What causes this, and what should I do to eliminate
the problem?
Thanks,
Dolly
the problem?
Thanks,
Dolly
tangle at all.
Maybe the size/spacing of the beads? Heishe-type and liquid silver
often catch neck hairs, but I haven’t heard of round beads doing
this.
Maybe the size/spacing of the beads? Heishe-type and liquid silver often catch neck hairs, but I haven't heard of round beads doing this.
Thanks Tas for your help.
It may be that I am stringing them too tightly.
Come to think of it, the worst ones are larger and heavy (like 10mm
or more) smooth round beads. I thought perhaps it had to do with how
tight they were strung together, or perhaps how thick the cord is. I
am spending some effort to get them tightly strung.
Guess I need to experiment a bit more. Dolly
Dolly - Define simple. Are you knotting your silk between the beads
or “simply” stringing them onto the silk which can result in beads
sliding (and grabbing hair) particularly if the silk stretches? Also
Margery Epstein in LA
Dolly - experiment with degrees of “tightly strung”. I find that
things that are TOO tightly strung do not lie well, and the beads rub
on each other. They may also be catching your hair. I like to allow
some degree of looseness, so the necklace drapes better and the beads
are not “attacking”
each other. Some things I do one way, decide
I just don’t like the way they are lying, and re-string them either
in another degree of tightness or using another stringing material.
Good luck!
Beth in SC
