Does anyone know what the correct oxygen and gas psi setting
is/should be for the Swiss Torch Hoke Style Head?
Also too, what is the correct setting for the little torch with a
size 7 head? People in the shop say put gas and oxygen up to 9 psi,
other people say put it up to 7, no clue.
psi, other people say put it up to 7, no clue.
There is no “right” pressure. The more pressure means more oxygen is
in a mixture, and that means higher temperature - until you reach
maximum flow that particular tip handle. If you are looking for the
maximum, it can be determined experimentally. I opt for the minimum
configuration. I use #5 tip, which was enlarged, so I have no idea
how it compares to #7. My regulator is set just bellow 5 psi.
I have just finished posting on Ganoksin blog about possible
modification to the torch tips.
If you are missing blowpipe
http://leonidsurpin.ganoksin.com/blogs/2010/02/14/
Two things I have to mention. If you are someone who uses casting
torch to replace prongs on 10-pointers, you probably would not be
interested.
Absolutely no testing of how safe the modification is, were
performed. The only reason that I am still around is due to my
enhanced ability to duck, when things start flying around. You may
want to keep it in mind.
